Heat
XRsteve
Posted 2011-06-03 9:45 PM (#87914 - in reply to #63959)
Subject: Re: Heat
Georgia, west of Atlanta
Can you ride comfortably in shorts now ?? It looks like your mod allows cool air that passes through the oval opening at the front of the bodywork to be directed so that not all goes to the front cylinder and some is bypassed out towards your legs..........Hmmm Interesting.............
Posted 2011-06-04 4:56 PM (#87951 - in reply to #63959)
Subject: Re: Heat
Guys I pulled the aluminum panel and with a fine tooth blade in my jig saw I cut it and then finished it off with a belt sander. You can get at the 4 10mm easy after you un do the top half. You need a ratcheting box end for the bottom bolt. All in all it was a two an a half hour job on a 90 degree day with high humility.
Very comfortable on the leg.
Edited by john frey 2011-06-04 4:58 PM
(IMG_0129.JPG)
(IMG_0130.JPG)
(IMG_0128.JPG)
Attachments IMG_0129.JPG (92KB - 5 downloads)
Attachments IMG_0130.JPG (72KB - 2 downloads)
Attachments IMG_0128.JPG (68KB - 1 downloads)
MaddMAx2u
Posted 2011-06-04 5:13 PM (#87952 - in reply to #63959)
Subject: Re: Heat
Orlando, FL
Aluminum panel? What's that? I think all the panels on my 2011 Vision are plastic!! Did Victory get cheap or greedy?
Cap'n Nemo
Posted 2011-06-04 7:20 PM (#87957 - in reply to #63959)
Subject: Re: Heat
New Bohemia, Va
since I put the tassles on the bike runs cool as a cucumber....
DannyB
Posted 2011-06-04 8:32 PM (#87958 - in reply to #63959)
Subject: Re: Heat
2 mi from Jim Beam n KY
<p>Looks good John!!</p><p> </p>
Edited by DannyB 2011-06-04 8:36 PM
MaddMAx2u
Posted 2011-06-04 8:56 PM (#87960 - in reply to #63959)
Subject: Re: Heat
Orlando, FL
Cap'n.....beggin yer pardon sir. "After I put the tassels on, the bike runs as cool as a cucumber"??
So yer wearing tassles now is it? ARGH! Shiver me timbers. And are ye topless when ye wears these here tassels? ARGH. I'm feelin' a visit to Davey Jones Locker is in order for sombody!
MaddMAx2u
Posted 2011-06-05 3:54 PM (#88021 - in reply to #63959)
Subject: Re: Heat
Orlando, FL
Someone made COOLING VENTS for the Vision!! Not sure I like the design, but someone did it!!
http://www.napalmmotorsports.com/custompage.asp?pg=custom
XRsteve
Posted 2011-06-05 4:26 PM (#88023 - in reply to #63959)
Subject: Re: Heat
Hmmm ???
Posted 2011-06-05 7:01 PM (#88043 - in reply to #63959)
Subject: Re: Heat
I looker up car vents like on your dash on ebay. It just didn't think I wanted to cut holes and not screw up. The vents would be nice
XRsteve
Posted 2011-06-05 7:23 PM (#88046 - in reply to #63959)
Subject: Re: Heat
Did you cut both sides ??
MaddMAx2u
Posted 2011-06-05 8:06 PM (#88052 - in reply to #63959)
Subject: Re: Heat
Orlando, FL
Also, when you made the cuts, did you have to touch up or re-paint??
Posted 2011-06-05 10:58 PM (#88066 - in reply to #88021)
Subject: Re: Heat
MaddMAx2u - 2011-06-05 1:54 PM
I think I like the looks of the stick on lowers better.
I have often considered cutting out the inner fairing. I am not worried about taking air flow away from the engine, considering how many Freedom engines are running on bikes without any fairings to channel the flow, I can't see that being an issue.
I would like to know how much cold air it lets in during winter riding?
I guess I haven't done it yet, because the heat hasn't been overbearing. After changing hwy pegs, I no longer find the need for the leather heat shields I made for my thighs either.
I have a feeling these thoughts will change when it hits 110F here in a week or so. I've got a set of lowers sitting in the garage, just waiting in their box, but I still like the cutout idea and keep going back and forth. IF HMD WOULD STOP TEASING US, I would have done something by now!
The beadrider seat, I will keep no matter.
Edited by Nozzledog 2011-06-05 11:16 PM
