rear shock movement
Banjodan
Posted 2013-05-16 9:13 PM (#139091)
Subject: rear shock movement
while checking clearances on shock and link bolts, I noticed [useing a small prybar} there is side to side or [front to back] movement on shock. about 1/2" is this normal?
atvtinker
Posted 2013-05-16 10:59 PM (#139093 - in reply to #139091)
Subject: Re: rear shock movement
Grand Cane, LA
Sounds like they didn't put the bushings back in that fit on the pivot pin on both sides of the bearing. You shouldn't have that much movement, maybe a 1/4" at most. Should be an aluminum bushing on both sides of the upper link at the pivot bearing.
Posted 2013-05-17 6:09 PM (#139130 - in reply to #139091)
here from what I see its just a bolt but wouldn't trust this drawing
(10VN.gif)
Attachments 10VN.gif (7KB - 3 downloads)
Posted 2013-05-17 6:14 PM (#139131 - in reply to #139091)
say go to net put in victory and click on web site. NOW in bottom left hand corner is parts list and owners manual. All you half to do is sing up
