GPS Cable cleanup
Yuma48
Posted 2008-12-01 9:11 PM (#24391)
Subject: GPS Cable cleanup
San Diego, California
Those of us that are using the Tourtech GPS have the cable disconnected when not in use. What do you do with the loose end. I put the plastic cover on and tuck it in the crack between the gas cover and the middle panel. Anyone else do something cleaner?
rmclarty
Posted 2008-12-02 6:54 PM (#24433 - in reply to #24391)
Subject: Re: GPS Cable cleanup
Is it the Garmin? I drilled a hole in the console between the GPS mount U Shape and fed the cable down through the console and hooked it up. When the GPS is off, I put on the plastic cover and it only sticks out about 2 inches and can be tucked back under the mount very cleanly.
Someone posted a picture of this installation but not sure where without doing a search.
Richard
Lotatoys
Posted 2008-12-04 12:33 PM (#24529 - in reply to #24391)
Subject: RE: GPS Cable cleanup
Here's the link Richard is referring to. It's pics of my Garmin install, posted on the VOG.net:
http://thevog.net/forums/display_topic/id_253/
This may not help with your current set-up but gives you an idea of how to conceal most of the cable.
Gary
Posted 2008-12-04 7:37 PM (#24556 - in reply to #24391)
Hey Gary, consider posting the photos and description here on Vision-Riders in the tech reference section. After all, it's the guys here that would be interested.
