trailer question
witchbiker
Posted 2011-12-29 10:03 PM (#104339)
Subject: trailer question
My question;
Is there in fact a plug, at or near the right side taillight area, that accepts a trailer 4-way plug for running lights, directionals, and brake lights for a trailer???
If not, do I need to connect into the wiring under the seat with some "tap-it" connectors, the same way I did for the led lights I already have for brake and directionals?
Thanks for anyone's help
ps: how do I make the font stay larger in these blogs??
witchbiker
victoryvisiontour
Posted 2011-12-29 10:31 PM (#104342 - in reply to #104339)
Subject: Re: trailer question
My '08 does not have a plug as standard. I tapped into the wires under the seat with a Reese plug.
https://picasaweb.google.com/105510930734514474102/2008VictoryVision...
(Reese 74672.jpg)
Attachments Reese 74672.jpg (12KB - 3 downloads)
Baddog69
Posted 2011-12-29 10:51 PM (#104344 - in reply to #104339)
Subject: RE: trailer question
Billings, MT
My '08 Vision didn't have a plug. I had to wire one for my trailer. The best advice is to wire the trailer with an isolator in to the circuit.
This step will make sure that anything in the trailer will not affect the bike's electronics of the computer that runs the whole works!
I did that in '08, and haven't had a problem since then!
victoryvisiontour
Posted 2011-12-29 10:59 PM (#104346 - in reply to #104339)
If the trailer has LED lights, no isolator needed. If incandescent bulbs, definately take Baddog's advice.
RiverRat
Posted 2011-12-30 5:56 AM (#104352 - in reply to #104339)
Southern Indiana
If you look in my picture gallery you will see a tap in harness I made up to put in the harness so when you tap into the wires you are not taping into the factory wiring.
