Error codes
jkfrazier
Posted 2015-04-19 2:38 PM (#171974)
Subject: Error codes
Fort Defiance, VA United States
Anyone know what these codes mean?
Thanks,
jf
(IMG_4291.jpg)
(IMG_4292.jpg)
(IMG_4293.jpg)
(IMG_4294.jpg)
(IMG_4295.jpg)
Attachments IMG_4291.jpg (49KB - 3 downloads)
Attachments IMG_4292.jpg (53KB - 0 downloads)
Attachments IMG_4293.jpg (51KB - 0 downloads)
Attachments IMG_4294.jpg (52KB - 0 downloads)
Attachments IMG_4295.jpg (53KB - 0 downloads)
cw1115
Posted 2015-04-19 4:17 PM (#171977 - in reply to #171974)
Subject: Re: Error codes
Ruskin, Fl
This is the last one. I can't figure the others out but the "2" and "3" errors all seem to be voltage to high or shorted to battery. Except for the las I can't find an exact match.
P0519 520193 7 Idle Air Control (IAC) position out of range.
Here is the chart from a 2012 XC manual:
NUMBER SPN FMI DESCRIPTION
P0107 102 4 Manifold Absolute Pressure sensor circuit voltage low - MAP portion of TMAP sensor circuit is
open, or shorted to ground.
P0108 102 3 Manifold Absolute Pressure sensor circuit voltage high - MAP portion of TMAP sensor circuit is
shorted to battery voltage.
P0112 105 4 Intake Air Temperature Sensor voltage low - Temperature portion of TMAP sensor circuit is
shorted to ground.
P0113 105 3 Intake Air Temperature Sensor voltage high - Temperature portion of TMAP sensor circuit is
open, or shorted to battery voltage.
P0117 110 4 Cylinder Head Temperature (CHT) Sensor voltage low - circuit shorted to ground.
P0118 110 3 Cylinder Head Temperature (CHT) Sensor voltage high - circuit open, or shorted to battery
voltage.
P0122 51 4 Throttle Position Circuit voltage low - TPS open, or shorted to ground.
P0123 51 3 Throttle Position Circuit voltage high - TPS shorted to battery voltage.
P0171 520204 17 Fuel Correction - system too lean Cyl 1 (Front).
P0172 520204 15 Fuel Correction - system too rich Cyl 1 (Front).
P0174 520205 17 Fuel Correction - system too lean Cyl 2 (Rear).
P0175 520205 15 Fuel Correction - system too rich Cyl 2 (Rear).
P0181C 520267 31 Kickstand Switch condition exists.
P0217 110 16 Engine Temperature Sensor - temperature too high.
P0231 1347 5 Fuel Pump Driver Circuit - open or shorted to ground.
P0232 1347 3 Fuel Pump Driver Circuit - shorted to battery +.
P0261 651 5 Injector 1 (Front Cylinder) driver circuit open or shorted to ground.
P0262 651 3 Injector 1 (Front Cylinder) driver circuit shorted to battery voltage.
P0264 652 5 Injector 2 (Rear Cylinder) driver circuit open or shorted to ground.
P0265 652 3 Injector 2 (Rear Cylinder) driver circuit shorted to battery voltage.
P0336 636 8 Crankshaft Position Sensor fault - missing tooth signal not detected in CPS signal within the correct
period of time.
P0443 520202 3 Canister Purge Valve - driver circuit short to battery +.
P0444 520202 5 Canister Purge Valve - driver circuit open or grounded.
P0503 84 2 Vehicle Speed Sensor - data erratic, intermittent, or missing.
P0508 520193 5 Idle Air Control (IAC) circuit or IAC motor shorted to ground.
P0509 520193 11 Idle Air Control (IAC) circuit or IAC motor open or shorted to battery voltage.
P0562 168 4 System Voltage Low - System voltage too low after the engine has been running for a specific period
of time.
P0563 168 3 System Voltage High - System voltage above allowable limit.
P0914 523 2 Gear Position Sensor Signal - signal fault
P0916 523 4 Gear Position Sensor Signal - voltage too low
P0917 523 3 Gear Position Sensor Signal - voltage too high
P1217 110 0 Engine Temperature Sensor - engine overheat shutdown. (2009 only)
P1351 1268 5 Ignition Coil Primary Driver Cyl 1 (Front) - driver circuit open or grounded
P1352 1269 5 Ignition Coil Primary Driver Cyl 1 (Front) - driver circuit short to battery +
P1353 1268 3 Ignition Coil Primary Driver Cyl 2 (Rear) - driver circuit open or grounded
P1354 1269 3 Ignition Coil Primary Driver Cyl 2 (Rear) - driver circuit short to battery +
P1501 520200 2 Tipover Sensor (Rollover) - signal fault.
P1502 520200 4 Tipover Sensor (Rollover) - voltage low.
P1503 520200 3 Tipover Sensor (Rollover) - voltage high.
P1504 520200 14 Tipover Sensor (Rollover) - tipover condition detected.
P1651 1213 5 Check Engine Lamp (MIL) - MIL lamp driver circuit open or shorted to ground. (2009/2010 only)
P1653 1213 3 Check Engine Lamp (MIL) - MIL lamp driver circuit shorted to battery voltage. (2009/2010 only)
P1710 2369 5 Right Turn Indicator Driver Circuit - driver circuit open / grounded. (2009/2010 only)
P1711 2369 3 Right Turn Indicator Driver Circuit - driver circuit shorted to battery + (2009/2010 only)
P1714 2367 5 Left Turn Indicator Driver Circuit - driver circuit open / grounded. (2009/2010 only)
P1715 2367 3 Left Turn Indicator Driver Circuit - driver circuit shorted to battery + (2009/2010 only)
Hope this helps. I would start by checking batter connections and voltage with a meter.
Posted 2015-04-19 4:58 PM (#171978 - in reply to #171974)
JF
what year is your bike what model.
How old it the battery. Is the bike charging when running.
Give more information would be nice
Posted 2015-04-19 7:58 PM (#171984 - in reply to #171974)
Good info. Been looking for a list like this for a long time. Repair manual has some, but not all.
jkfrazier
Posted 2015-04-20 8:46 AM (#171989 - in reply to #171978)
2010 Vision.
Original battery although I have always kept it on a charger.  Further, I have had these errors on and off since the bike was 6 months old.  It runs fine without any known issues.
I had a Vic dealer hook up to the bike with diagnostic equipment a few years ago while they had Victory on the phone discussing these errors.  Essentially, they were not able to determine the problem or cause.
This is the first time I have noticed it in a while, although it may occur more than I realize, because unless you toggle through the screens, you may not notice any errors.
Obviously, there is something causing these errors.
jf
