Gatlin tip install problem
proffsionl
Posted 2008-10-24 9:32 AM (#21482)
Subject: Gatlin tip install problem
Austin, Texas
Okay, so I got the three bolts loosened and replaced the right side tip with the new Gatlin. I go to do the left side. I loosen (and get out) two of the bolts. The third (middle) bolt is not really gettng loose. Turns out the threaded collar on the original exhaust tip is just spinning with the bolt. I can't find an obvious way to keep the collar from spinning.
Any ideas on this one?
Kevin
cdevon1200
Posted 2008-10-25 1:19 PM (#21579 - in reply to #21482)
Subject: Re: Gatlin tip install problem
remove the muffler cut the bolt head off. or "try" to cut the bolt head off while its on the bike, by using just the hack saw blade...
good luck.
cdevon1200
VaParadox
Posted 2008-11-02 8:59 AM (#22279 - in reply to #21482)
Richmond, Virginia
Sorry to hear you have the bolt problem, if its any consequence, I just put on my new tips and your effort will be worth it !!! they look awesome.
Flatsix
Posted 2008-11-02 5:13 PM (#22299 - in reply to #22279)
Fargo, ND
and they sound ?
Digby
Posted 2008-11-02 6:20 PM (#22304 - in reply to #21482)
No different really ,the good looks are well worth it. Other people even non biker types pick up on them right away .
