Will the VFC III control any surging?
g1nomad
Posted 2009-07-02 4:25 PM (#37949)
Subject: Will the VFC III control any surging?
SC, Bluffton
*** you can substitute "slight stalling" in place of surging in this paragraph. ***
I ride in the 2,700-3,100 RPM range. I feel lots of surging in the 1st-3rd gears. The only way I can describe it is you are cruising along and there is some good smooth power, now its gone, its back, its gone, its back, its gone, etc....My Honda's & Kawasaki's have never done this. This is with the throttle in the exact same position, same RPM. I have had every service done at every interval. I don't think there is anything wrong outside of what Victory put out.
If I installed Lloyd's diffuser & the VFC III, would this dissapear? Is this an EPA thing? I don't ever go above 4,000 RPM, and I am keeping stock pipes (Level 0, stage 0 ?).
If this would be a good thing for me, who is having a 4th of July sale?
Thank you, Herb
Edited by g1nomad 2009-07-02 4:27 PM
buddahead
Posted 2009-07-02 11:24 PM (#37978 - in reply to #37949)
Subject: Re: Will the VFC III control any surging?
SF Bay Area
I'm no expert but my guess would be that the surging may be caused by the O2 sensors and the closed loop system doing their thing, together.
Adding a reprogramming device that recommends disabling the O2 sensors may help with your surging.
Kevin... ?
bigwill5150
Posted 2009-07-02 11:56 PM (#37979 - in reply to #37949)
Reno County, KS
I would clean and refasten everything in your "Control Loop" i.e. battery and alternator connections, throttle cable, etc. I have had the bike start surging one time in cruise after about 2 hours in the heat. Ultimately I followed the service manual steps to zero the cruise control to fix it.
Lloyd
Posted 2009-07-03 9:43 AM (#37988 - in reply to #37949)
Subject: RE: Will the VFC III control any surging?
Yes the VFC lll will cure surging at the lower speeds. You don't have to do any thing else with it if you want to keep your stock exhaust.
Lloyd
airguy
Posted 2009-07-04 10:20 AM (#38045 - in reply to #37988)
Hinton, Iowa
Herb, I sent you a PM
