gas cover door alignment
IndyVision
Posted 2009-07-28 2:34 PM (#40147)
Subject: gas cover door alignment
My door is rubbing on the top left corner when you open and close it. It has rubbed the paint off the fairing. Anyone else have this problem? The entire door looks like it has moved 1/16 of an inch up when compared to the door for the Ipod.
Posted 2009-08-26 11:40 AM (#42476 - in reply to #40147)
Subject: Re: gas cover door alignment
indy, i've not had this problem, but curious if you ever got yours corrected?
IndyVision
Posted 2009-08-26 12:07 PM (#42477 - in reply to #40147)
No. My dealer told Polaris that my bike fell over when it was towed, and Polaris said that would probably caused the problem. I had the problem before it fell over on the left side. I'll probably have my dealer call again next time I take the bike in for service. I have almost 20K miles on it and my front tire is looking bad. One thing Polaris said was there is no adjustment. The fairing would have to be removed and adjustments made by slotting bigger holes.
Posted 2009-08-26 2:15 PM (#42488 - in reply to #40147)
indyV i think if you were to just pull the fairing off and put it back on, relieving any stress may do the trick. i know after getting jammed in the left rear a few months back that is all i did and everthing is back in place.
Crawford
Posted 2009-08-26 2:29 PM (#42492 - in reply to #40147)
Regina Saskatchewan Canada
A friend had the same problem after the dealer had to take the top all apart to replace something and after he had an alinement problem. The Dealer had to correct the problem because it wasn't like that before.
