Aerostitch ear cannon- any install issues ?
hottierod
Posted 2010-02-26 9:05 AM (#53981)
Subject: Aerostitch ear cannon- any install issues ?
Sturbridge, Mass
http://www.aerostich.com/ear-cannon-air-horn.html
anybody have one ? any install issues ?
Thanks
Jeff
Lotzafun
Posted 2010-02-26 11:12 AM (#53986 - in reply to #53981)
Subject: Re: Aerostitch ear cannon- any install issues ?
Rockford, IL
Its a Stebel Nautilis horn. Many of us here have installed these. Do a search using "Stebel" and you will find quite a few posts regarding them.
Gotta say that I think the $37 price is the cheapest I've seen.
Posted 2010-02-26 3:19 PM (#53996 - in reply to #53981)
Subject: RE: Aerostitch ear cannon- any install issues ?
hottierod - 2010-02-26 9:05 AM http://www.aerostich.com/ear-cannon-air-horn.html anybody have one ? any install issues ? Thanks Jeff
Like Lotzafun said the air horn is a Stebel Natutils.
I did an install last month and posted it in my Gallery.
I thought there was enough information already on the air horn but maybe I should do a tech reference post.
You can click on the images to make them bigger.
Edit caption
Made a bracket from 1/4" x 1" x 2 1/2" aluminum. Bent the bracket at a 40-45 degree angle. Which allows the brake lines to clear the air horn. Drilled two holes in the aluminum bracket and mounted using one of the gas tank bolts. Grounded the horn using the factory horn location.
Edit caption
Stebel Air Horn mounted to 1/4" thick aluminum bracket.
Edit caption
Bolted horn relay up out of the way.
Edit caption
Wired horn (+) to #87 on relay - horn switch (grey wire) to #86 on relay - grounded #85 on relay - power from battery side terminal to #30 on relay with an in line 20amp fuse.
Edit caption
20 amp in line fuse
Edit caption
Stebel Air Horn clears brake lines,fairing and grill
Edited by Thomas 2010-02-26 3:30 PM
hottierod
Posted 2010-03-17 8:59 AM (#55133 - in reply to #53981)
Sturbridge, Mass
ordered this along with the wiring harness.
Dealer installed into exsiting horn location- no mod's needed (according to them).
Let me say, this is LOUD !!!!!!!!!!
well worth the money....
Prostreet1
Posted 2010-03-17 11:07 AM (#55138 - in reply to #53981)
Allen Park, MI
I put mine on last year.....and have since put one on my CJ....its loud as hell!!
