ECU set up
TRELL
Posted 2011-11-19 6:32 AM (#101822)
Subject: ECU set up
Well on my vtx1800, put power comander on have a disc that goes in laptop to set up. Does victory have a disc or some mean of reflashing their control units?
g1nomad
Posted 2011-11-22 10:36 AM (#102027 - in reply to #101822)
Subject: Re: ECU set up
SC, Bluffton
Trell, I think only autorized Victory dealerships can do this. My Vision is running like crap, and has been for over 1\2 year. I no longer have a local dealership, and some on the forums think I have an air-idle control valve issue of some sorts that a dealership can flash and fix just like that. One of these days, one of these days.
I don't read much about the Vision CAN bus system. I think that is the electrical cannection inside of the compartment were the rear shock's air vavle is? I assume this is what they plug into the computer for the ECM?
Herb
Edited by g1nomad 2011-11-22 10:38 AM
Posted 2011-11-22 2:39 PM (#102038 - in reply to #101822)
the ECU reflash is by using Victory's digital wrench hardware/software. this can Not be done by a customer. and to be honest i think the ecu fuel map flashes are $hit anyways. i know because i had a s1l1 reflash on my 2008 vision and it barely did anything. if anything it ran worse.. then the service manager at the victory shop i went to told me that all the victory fuel maps have to meet EPA REGS which means they are going to be LEAN !! so even if they let a little more fuel in, they are still lean.. my vision(s) didnt start to run real good until i installed my power commander 5 ... i will No longer play with those Epa approved victory fuel maps.
TRELL
Posted 2011-11-22 4:59 PM (#102045 - in reply to #102038)
Arkainzeye - 2011-11-22 2:39 PM
Can you go into the PC5 detail alittle more. thanks
Posted 2011-11-22 5:06 PM (#102046 - in reply to #102045)
TRELL - 2011-11-22 4:59 PM
what do you want to know about it? ill try my best to answer questions you may have.
http://www.youtube.com/watch?v=tcgcost-mPs
Edited by Arkainzeye 2011-11-22 5:08 PM
TRELL
Posted 2011-11-22 7:52 PM (#102065 - in reply to #102046)
Thank You youtube vid explain to me what i needed Thanks for posting it..TRELL
