Battery terminals won't stay tight
cw1115
Posted 2013-04-27 7:42 PM (#137716)
Subject: Battery terminals won't stay tight
Ruskin, Fl
So I'm am right at 11K on my bike. About a month ago I started hearing a squealing noise from the motor. It sounded just like a bad belt on a V8. Kinda had me baffled cause it went away after the bike was hot. It turns out both battery terminals were loose and the charging system wasn't happy.
I tightened them. It lasted less than a week and the noise was back.
When I retightened I realized the battery itself was loose. You could move it in the bracket causing a squeak also.
I assumed the loose battery was cause the cables to loosen. I put a piece if rubber between the battery and the bracket and retightened the terminals with split lock washers.
Loose again a couple of days later. Since then I switched to external tooth lock washers and than blue lock tight.
FN thing keeps coming loose. I even tightened to the point of starting to twist the term on the battery.
I'm going to the dealer Wednesday, but was wondering if anyone had a similar issue.
Sorry for typos. Using smartphone.
Posted 2013-04-28 6:29 PM (#137774 - in reply to #137716)
Subject: Re: Battery terminals won't stay tight
use star washers any hardware store 1/4" size or lock washers one per thermal
(IMG_0439.JPG)
Attachments IMG_0439.JPG (32KB - 0 downloads)
cw1115
Posted 2013-04-29 5:19 AM (#137816 - in reply to #137716)
Ruskin, Fl
Thank you. I tried those the split lock washer and before the Loc-tight.
I thing it's loose tolerances between the nut and bolt on the battery.
Posted 2013-04-29 6:06 AM (#137817 - in reply to #137716)
The setup is simple. If you are having a problem with a loose terminal, replace the battery, if it's just the hardware, bolt, nut, and washer, replace those for around a dollar.
cw1115
Posted 2013-04-29 7:13 AM (#137824 - in reply to #137716)
Ruskin, Fl
Thanks Varyder. I'm gonna let the dealer mess with it. Also have the squeak from battery movement.
I'll let you know what happens Wednesday.
wingit3611
Posted 2013-04-29 9:15 AM (#137846 - in reply to #137716)
Don't seem to me like the battery should be moving & that's what is causing the cables to come loose! I'd have to look up what it is that holds it. Maybe some one that just replaced a battery will remember
