lite bar
vic2004-08
Posted 2009-10-30 9:21 PM (#46820)
Subject: lite bar
Lusby,Md
Just installed the brake/turn signal light bar from Custom Dynamics,installed it just under the trunk lid.Installation was pretty easy,had to extend the wires a little so they would reach the harness.Looks and works great.Saw pictures from another person that posted it .Extra lighting can't hurt!
DAL
Posted 2009-10-31 1:42 AM (#46829 - in reply to #46820)
Subject: RE: lite bar
Vancouver, B.C. & La Quinta, CA
Do you have any photos?
vic2004-08
Posted 2009-10-31 10:25 AM (#46833 - in reply to #46820)
Lusby,Md
A picture from another post.
(Tank LEDS.jpg)
Attachments Tank LEDS.jpg (45KB - 1 downloads)
Amibrau
Posted 2009-10-31 11:13 AM (#46834 - in reply to #46833)
The Great Northwet
Robert,
Kinda looks like you put it in the gap between the lid and trunk? Or is it on the trunk itself? Any additional info like part number from Custom Dynamics, additional pictures, etc. would be greatly appreciated. I have a similar light bar that I bought a couple of years ago and never installed so this could really give me leg up before I install. Thanks.
vic2004-08
Posted 2009-10-31 4:45 PM (#46837 - in reply to #46820)
Subject: Re: lite bar
Lusby,Md
I put it between the gap of the trunk lid and trunk,drilled small holes in the inner lid to run the wires inside the lid and out the right hand trucklid hinge.Had to add wire so the wires would reach the wire harness on the right side underneath the seat.In the kit there is a splitter so you can run a running light,but I didn't use it.Black is ground,white/red is the brake lite ,blue is the left turn signal,blue/pinkis the right turn signal and green/pink is the running lite.And if you go to Custome Dynamics .com the item number is -- ST6126ARA,6 amber on each side and 12 red in the middle.If you look at one of the past post about people asking questions about the Kuryakin light hook up to make the trunk lights turn/brake lights another guy had more pictures of this.Hope this helps.
Amibrau
Posted 2009-11-01 11:02 AM (#46867 - in reply to #46837)
The Great Northwet
Thanks, good info.
