New vision no owners manual yet still...
freezeradio
Posted 2009-11-16 6:47 PM (#47845)
Subject: New vision no owners manual yet still...
Oswego,, Illinois,USA
Does anyone know how to set the time on the vision tour . I have no owners manual yet. store will be open tomarow ,So I will slow down on the questions soon
Don Nieshe
Posted 2009-11-16 8:17 PM (#47854 - in reply to #47845)
Subject: RE: New vision no owners manual yet still...
1. Turn key on to acc to view the clock.To change the setting use the mode button to toggle to the odometer.
2.Press and hold the Mode button untill the hour segment flashes,then release the button.Tap the Mode button to advance the setting.
3. Repeat step 2 to set the 10 minute segments and the 1 minute segments,then press and hold the Mode button to save the settings and exit the Clock set mode.
4.Turn key off The clock is set untill the batery is dicconnected or discharged.
As printed in the manual
freezeradio
Posted 2009-11-16 9:25 PM (#47856 - in reply to #47845)
Subject: Re: New vision no owners manual yet still...
thanx got it
Tennessee Vision
Posted 2009-11-16 11:59 PM (#47864 - in reply to #47845)
Spring Hill, Tennessee
Behind the switch housing on the left side handle grip there is a button. Hold this button until the time starts to flash on your display. Then release the button and click it repetatively until the "hour" you desire is set. Hold the button again until the "minute" begins to flash on your display. Repeat this until your time is correct. Then press and hold the button one more time to exit the time set mode.
Does that make sense to you? I am doing it in my head as I type. Not sure that your brain will visualize the process the same way?
Let me know?
Thanks
RedRider
Posted 2009-11-17 5:34 AM (#47866 - in reply to #47845)
Finally someone that reads manuals and doesn't have one.
freezeradio
Posted 2009-11-17 3:25 PM (#47889 - in reply to #47845)
Went and got my owners manual today... Alot of questions not going to be asked .... bummer... kind of fun chattin with yall.
