VV Grab Bar removal
ScottMorgan
Posted 2010-10-01 3:44 PM (#70798)
Subject: VV Grab Bar removal
I need to remove the Pass. Grab Bars for painting. ? is, is it pretty obvious when I open the saddlebags or is there a trick to removal....
Scott.Morgan@adm.com
Posted 2010-10-01 3:56 PM (#70799 - in reply to #70798)
Subject: Re: VV Grab Bar removal
Here is one method described twice.....
Here is one with pictures....... http://www.vision-riders.com/bb/forums/thread-view.asp?tid=5227&pos...
Here Flatsix wrote.... http://www.vision-riders.com/bb/forums/thread-view.asp?tid=4223
I removed and painted mine and found the removal to be not bad. I removed the seat, license plate bracket, and panel around taillight. Unscrew the latches on your bags, remove 4 screws holding the computer down and the 4 bolts close to the computer. Loosen the 2 bolts inside the bags on the vertical panels and you can then move the base the computer mounts to from side to side and lift it up to get at the grab rail bolts very easily without cutting. Paint em and reverse the procedure.
Good Luck!
John / Fargo, ND / 82 & Sunshine
Edited by radioteacher 2010-10-01 3:59 PM
Lotzafun
Posted 2010-10-02 9:57 AM (#70814 - in reply to #70798)
Rockford, IL
Another option...... http://www.vision-riders.com/bb/forums/thread-view.asp?tid=3428&pos...
Posted 2010-10-02 5:09 PM (#70825 - in reply to #70798)
Lotzafun,
Thanks! I knew there was another way but I could not find your post.
Ride Safe!
ScottMorgan
Posted 2010-10-03 8:17 PM (#70907 - in reply to #70798)
Subject: RE: VV Grab Bar removal
Thanks all. it should be doable,,, even with limited mechanical aptitude...
Highwayman
Posted 2011-03-04 12:17 PM (#80756 - in reply to #70798)
Iowa
I just took the Vision apart for painting and I followed these instructions for the grab rails. It worked perfect. No cutting needed. Thanks for sharing. Now off to the painter.
