Wrong Installation Instructions for Heated Grips
ricvic
Posted 2010-10-03 10:09 PM (#70918)
Subject: Wrong Installation Instructions for Heated Grips
Not sure if there are many of you putting heated grips on your Roads but if you do, the Victory instructions that come with them are wrong for the ROADS. How do we get to Polaris so they can make the correction so someone doesn't burn up their bike....Jeff, is that you?
In instruction #10 they tell you to connect the DARK BLUE wire from the kit wire harness to the BLUE wire on the (main electrical harness... this should say the grip harness).
It repeats the same error for the BROWN wire from the kit wire harness to be connected to the BROWN wire on the main electrical harness... it too should be connected to the grip harness, not main.
Hope this helps someone.
Posted 2010-10-04 5:04 AM (#70923 - in reply to #70918)
Subject: Re: Wrong Installation Instructions for Heated Grips
ricvic,
What year is your Vision?
Posted 2010-10-04 5:57 AM (#70925 - in reply to #70918)
RT - I believe he has a CrossRoads...
Posted 2010-10-04 7:29 AM (#70931 - in reply to #70918)
OK now that I am awake....I wonder if the instructions are for a Vision....not the Roads?
glighto11
Posted 2010-10-04 7:55 AM (#70934 - in reply to #70918)
Central New York
Instructions sound fine to me. Hook the kit to main harness. Unless you have one in the box, there is no "grip" harness.
ricvic
Posted 2010-10-05 6:28 PM (#71079 - in reply to #70918)
Yes, I have already installed this (correctly, however) and there is a grip harness for the CR grips. I did not look to see if they were for the Vision or Country as I was only interested in the Roads.
