VV 2013 rear trunk power outlet fuse
Lomcevak
Posted 2015-02-12 3:59 PM (#169797)
Subject: VV 2013 rear trunk power outlet fuse
, QC Canada
Hi guys, does anyone know wher is located the fuse for the rear trunk powerlet. I accidentally grounded it and now, no power in it.
Thanks for your help
Posted 2015-02-12 5:41 PM (#169799 - in reply to #169797)
Subject: RE: VV 2013 rear trunk power outlet fuse
Raise your windshield and then pop the cover on the front of the bike off. Be gentle as you lift it because the radio antenna is attached to the underside. Unplug it and remove the cover. There are two fuse boxes under the cover below the windshield.
Posted 2015-02-12 5:57 PM (#169800 - in reply to #169797)
Subject: Re: VV 2013 rear trunk power outlet fuse
read your owners book it will tell you wear
BumbleDB
Posted 2015-02-12 7:09 PM (#169801 - in reply to #169797)
I'm pretty sure you won't be able raise your windshield, because it's the same fuse. 20A. You can get to it with the ws down, but it's a pain.
Lomcevak
Posted 2015-02-13 9:14 AM (#169808 - in reply to #169801)
, QC Canada
Thanks guys. I know where the fuse boxes are, and my windshield was already in the up position. I was just trying to locate which fuse was out without removing all of them to check . 😎
Posted 2015-02-13 5:49 PM (#169822 - in reply to #169797)
owners book will tell you
