Help-------
stoney
Posted 2012-05-25 7:43 PM (#115201)
Subject: Help-------
Endicott, NY 2011 Vision
I'm trying to drill a hole in my Vision panel for the Garmin 660 harness to go through. It calls for a #16 metric drill. Seeing that I don't have such an animal would anyone know what the equivalent size a standard bit might come close? Thanks for your reply.
Posted 2012-05-25 7:45 PM (#115203 - in reply to #115201)
Subject: Re: Help-------
norcan
Posted 2012-05-25 10:41 PM (#115219 - in reply to #115201)
Edmonton Alberta, Canada
As Varyder said, 16mm = 5/8", only hoping they are not asking for number drill bit size. I have a chart at work for that but am sure there would be a google site to convert.
Posted 2012-05-25 11:48 PM (#115221 - in reply to #115201)
Subject: RE: Help-------
5/8" is huge! Make sure that's what you want to do, it will be hard to cover that up if it's wrong.
Is that going under the Vision's GPS accessory bracket?
I am using a RAM mount, so I chose to drill a much smaller slot thru the key bezel. This way I would not need to drill a large hole in my dash and the bezel would be much cheaper to replace.
(2012-05-25 21.25.58.jpg)
(2012-05-25 21.32.03.jpg)
Attachments 2012-05-25 21.25.58.jpg (63KB - 2 downloads)
Attachments 2012-05-25 21.32.03.jpg (61KB - 0 downloads)
wseemann
Posted 2012-05-26 11:01 AM (#115250 - in reply to #115201)
Boydsville, AR United States
Now that is one cool neat idea to get the cable up, and be neat. Cheep to put back to stick too, if you sell.
Posted 2012-05-26 1:03 PM (#115257 - in reply to #115201)
this will help and are you sure on the 16mm
http://www.boltdepot.com/fastener-information/Metric-Tap-Drill-Size...
CoolHandLuke
Posted 2012-05-26 6:36 PM (#115261 - in reply to #115201)
, FL United States
Darrell, you rock! What a neat and functional modification.
