Gas on my leg
Lovmyvic
Posted 2012-06-16 5:35 AM (#116775)
Subject: Gas on my leg
New Hampshire
The other day left for work on my 08 Vision. It is stock. I got on it real good, I felt what I thought was water on my right leg. When I left work the same thing. Come to find out it was gas. Has any body else had any thing like this happen to them? I looked to see if a line had a whole in it and found nothing. Any help would be great. Thank you Larry
Posted 2012-06-16 5:41 AM (#116776 - in reply to #116775)
Subject: Re: Gas on my leg
make sure you have a overfill drain tube, and it goes all the way to below the engine. Did you just fill it up? Also, could be a bad cap also. Check for the hole in the line that you suspect.
Lovmyvic
Posted 2012-06-16 5:45 AM (#116777 - in reply to #116776)
New Hampshire
Ok I will look at drain tube, I have changed the cap. But I do still have a smell of gas.
Posted 2012-06-16 2:01 PM (#116809 - in reply to #116775)
Is your lip on the gas tank bung bent? If so channel locks could bend it back in place
Mattchristiani
Posted 2012-06-16 9:03 PM (#116820 - in reply to #116775)
Cedar, Michigan
Did this one time also. My issue was a very full tank and I failed to put the gas filler cap on correctly.
Cometman
Posted 2012-06-18 2:29 PM (#116979 - in reply to #116775)
Simi Valley, CA
Get a new gas cap... I had the same thing on my 09 and it was replaced under warranty.
Monkeyman
Posted 2012-06-19 12:00 AM (#117027 - in reply to #116775)
Peru, IN
I thought I had "gas on my leg" once. Turned out it was more than just gas. Damn extra spicy burritos.
