Poll Betl chirp noise was it fixed in a model year
OptionResults
2008 Vision chirp16 Votes - [37.21%]
2009 Vision chirp5 Votes - [11.63%]
2010 Vision chirp1 Votes - [2.33%]
2011 Vision chirp3 Votes - [6.98%]
2012 Vision chirp0 Votes - [0%]
2013 Vision chirp0 Votes - [0%]
2008 NO Vision chirp8 Votes - [18.6%]
2009 NO Vision chirp1 Votes - [2.33%]
2010 NO Vision chirp1 Votes - [2.33%]
2011 NO Vision chirp5 Votes - [11.63%]
2012 NO Vision chirp2 Votes - [4.65%]
2013 NO Vision chirp1 Votes - [2.33%]
orlean1
Posted 2012-09-17 12:19 PM (#123778)
Subject: Betl chirp noise was it fixed in a model year
Hi All I have searched thru all the chirping sound threads and looked at a lot of the model years.  I did not notice a lot of owners with 2012s or later reporting the noise.  I was wondering if Victory has fixed that problem.  I created a poll to get an idea of what years are experiencing the problem.  I could not find a search on this if I have missed it I apologize.  Also, if the problem was fixed permanently could you let everyone know what that fix was.
Thanks
Vince
Posted 2012-09-17 2:11 PM (#123787 - in reply to #123778)
Subject: Re: Betl chirp noise was it fixed in a model year
early '08 model, never had the chirp, I did have a growl until I set my belt to the new specs, no problems since then. Can't vote as it never applied to me.
Posted 2012-09-17 3:33 PM (#123804 - in reply to #123778)
I went to the store and bought canning wax. Its $2.98 for a life time supply. Rubbed it on the hole outer edge of the belt and now five thousand miles later still quiet. Oils and dry film draws or holds dirt and dirt will cut the belt.
If you read how to adjust the belt you can all most fix it.
I measured my belt and found the belt width very's by as mush as 25 thousand. Not a true cut for sure. If the belt was a 1/8" narrower we wouldn't have a problem I think.
Posted 2012-09-17 5:29 PM (#123819 - in reply to #123778)
i didnt have chirping on Both my vision (08)-(11) but i DID have a whirling noise on my 11, it was caused by sandy/dustiness on the belt.. i read the 11 service manual and was made aware of this.. I WASHED the belt and it went away... i then also loosened the belt by the slightiest amount... I did this ONLY because on longer days (400+ miles) the belt would get Tight.... i also read about this as well.. when it got tight that when the whirling would get worse. so since i washed and "loosened" the belt it has been 800 miles with No noises at all..
btw all that i mentioned i learned from Reading the vision serivce manual..
Edited by Arkainzeye 2012-09-17 5:30 PM
norcan
Posted 2012-09-18 12:15 AM (#123848 - in reply to #123778)
Edmonton Alberta, Canada
My 08 chirped after new tire installed and about 500 miles. However after readjusting tension never has chirooed again, that being 3 new rear tires. I believe the chirping comes from poorly adjusted rear tire. If chirping belt is loose.
donetracey
Posted 2012-09-18 12:41 AM (#123849 - in reply to #123778)
Pitt Meadows, BC Canada
But how about that goddanged squeal when you ride the clutch on a high-rev start in the wrong gear ??? (2nd..)
Makes me feel stuuuupid
kmt27
Posted 2012-09-18 10:09 PM (#123913 - in reply to #123778)
Subject: RE: Betl chirp noise was it fixed in a model year
Davenport, IA
My 09 chirped when it was new. I did the first 500 mile service myself and adjusted the belt. Since then, and after two tire changes while pulling the tire and adjusting belt myself, no chirping. key is, proper belt adjustment! Belt a little loose is better than a belt a little tight. Thanks to many who have posted here on adjusting the belt! Has helped me out tremendously!
