Need Air Shock Schrader Valve - Can Anyone Help?
Tjim01
Posted 2009-06-30 5:49 PM (#37819)
Subject: Need Air Shock Schrader Valve - Can Anyone Help?
All - I'm rebuilding a formerly wrecked Vision and it's missing the Schrader valve on the end of the air line for the rear shock....can anyone help locate one - or I.D. the specifics of this valve? Doesn't appear to be available separately from dealer.
norcan
Posted 2009-06-30 5:59 PM (#37821 - in reply to #37819)
Subject: Re: Need Air Shock Schrader Valve - Can Anyone Help?
Edmonton Alberta, Canada
Have you tried a std schrader valve? Looks to me it is a std tier model.
Posted 2009-06-30 6:19 PM (#37823 - in reply to #37819)
Subject: RE: Need Air Shock Schrader Valve - Can Anyone Help?
Tim, welcome to the forum.
1. I would think the shock and hose is a single unit. It says in the manual if there is problems, replace.
2. I hope all is well from the crash. I'm thinking you bought it crashed for a project...???
3. Pictures, before and after and detail reports are greatly appreciated.
I know of one Vision that was in a rear end collision and trashed the entire rear of an Annie. Well, when the dealer took off all the plastic, there was nothing wrong with the structure/frame, period. They order all new body parts and put him back on the road.
I got pushed about three feet from a guy rolling into me at a stop sign. Other then some scuffs on my left bag, nada. I just pulled the pipes off and the left door and found nothing that would indicate there was even a contact. I got a check to replace the left side bag, door, and lower piece + labor because of the marks. I buffed the marks out the check was enough to buy my tires, belt and oil change and take the wife out to dinner.
I hope we can see what the finished product looks like.
Tjim01
Posted 2009-06-30 8:49 PM (#37829 - in reply to #37819)
Thanks guys...the Schrader valve is different from a standard tire.
I did buy this already wrecked as a project - pretty much all plastic from the seat rearward was broken, but no sign of damage to wheel, frame or any other structural part. I will post before / after pics later...should be finished by the weekend (schrader valve or not - I may have to cap it off temporarily - but I'm riding this weekend).
Jim
Teach
Posted 2009-06-30 8:53 PM (#37830 - in reply to #37819)
You should be able to make a Harley Air Shock valve work. Might take a little modifying but I suspect they sell just the valve for the air suspension on the Tour models. Good luck
Posted 2009-06-30 9:11 PM (#37833 - in reply to #37829)
Tim, I didn't look at it close when I was under mine recently, but how is the hose attached to the shock? I think might be the trick is to replace the entire hose and valve and that should solve your problem if you can find a hose that will work. Just a suggestion...
Lotzafun
Posted 2009-07-01 8:40 AM (#37845 - in reply to #37819)
Rockford, IL
While it is larger than most schrader valves, something tells me that a local bicycle shop probably has the correct size valve. I think I've seen this size on a few "higher-end" bicycles, so you might need to stop by a couple shops before you find one.
Or you can always try this place http://www.mcmaster.com
