Victory/fox air pump 300psi gauge
joeC
Posted 2010-06-23 9:12 PM (#62991)
Subject: Victory/fox air pump 300psi gauge
New York
I just purchased a new Victory/fox air pump from my dealer part #2876654 and noticed that the gauge on the pump reads up to 300psi and 20bar... Since the owners manual says never to exceed 72psi why didn't Victory find a gauge that only reads to 100psi?? Wouldn't that be more accurate?
The reason I ask this is because when I put the pump on the valve stem it read zero.. and I thought that was odd... then if you look closely on the gauge there is only 3 red lines before 50psi... thats messed up in my book! Or am I missing something??? I wanted to put approximately 35psi in what line would you use to get that amount? I hope you think I'm ... awww.. never mind!!!
Joe
Edited by joeC 2010-06-23 9:16 PM
Bubba
Posted 2010-06-24 5:24 AM (#63011 - in reply to #62991)
Subject: Re: Victory/fox air pump 300psi gauge
Take the bike back, that is just horrible.....?????
norcan
Posted 2010-06-24 6:10 AM (#63013 - in reply to #62991)
Edmonton Alberta, Canada
change the guage to a 100 psi unit. Or return it and have them get you the right unit!
VisionTex
Posted 2010-06-24 6:52 AM (#63016 - in reply to #63013)
LaPorte,Tx.
That's not like the pump I have. Mine reads in 5 psi increments, can't remember but probably goes up to ~100 psi, and reads the pressure as soon as hooked up.
VICTORYTCRIDER
Posted 2010-06-24 7:05 AM (#63021 - in reply to #62991)
Capitol Region of NH
I would return that unit. I use the 100 PSI pump from Progressive. Work really well. It does not lose air when connecting and disconnecting and has a button for air release if you need to let some out. Pumps up really fast and can be used for tires in a pinch.
Webhair
Posted 2010-06-24 10:13 AM (#63038 - in reply to #62991)
Peachtree City, GA
Can you share more details of the Progressive unit?
joeC
Posted 2010-06-24 3:14 PM (#63062 - in reply to #62991)
New York
Thanks for all the information everyone... I'll call parts at the dealership and see if he can't get me an airpump that goes to 100psi and exchange this unit..
