amp install?
Jump to page : 1 2 3 4
Now viewing page 4 [25 messages per page]
Ditch
Posted 2013-05-20 4:47 PM (#139258 - in reply to #79070)
Subject: Re: amp install?
I personally would not use a capacitor on such small speakers. normally you would use a capacitor on a subwoofer the draws a lot of power not midrange speakers.
Ditch
Posted 2013-05-20 5:53 PM (#139262 - in reply to #79070)
That's strange, unless your bike just isn't providing enough amperage for your amps draw. My alpine has under and over voltage proetection and yours probably does as well. The first thing I would do is just confirm that the amp is going into protect mode then you obviously have to find out why. Turn your fader all the way to the front and turn it up to see what happens, then try the backs by themselves. At least you can isolate which speaker and or wires need attention. Make sure your speaker wires from the amp are adequate size, at minimum 14 gauge and preferrably 12 gauge. If it is not an under volt / under amp or a shorting speaker wire you need to make sure its not an overtemp issue with the amp.
Hope that helps, sorry for errors but I am doing this from my pos phone.
Edited by Ditch 2013-05-20 5:55 PM
tkleroi
Posted 2013-06-01 1:47 PM (#139801 - in reply to #139262)
Thanks for the help guys I need to chk my BAT too I had to replace it with a battery from AUTOZONE at the time and place that was the only place close by but I dont remember if it is the proper size and power. since I put it in
tkleroi
Posted 2013-06-06 1:06 PM (#140046 - in reply to #139262)
Funny I did try the fader the back speakers work when I turn the volume all the way up. BUT the fronts turn off when I turn up to 12 only when im riding not at stand still. I have to turn off the radio then turn it back on the get any sound
