Heard On The Street Is A Lie
Posted 2016-08-30 4:34 PM (#188661)
Subject: Heard On The Street Is A Lie
this is whats posted. Don't believe it. You have to remove the exhaust
The Vision's rear tire and belt can be changed WITHOUT removing the bags, you simply need a jack."
Posted 2016-08-30 7:05 PM (#188663 - in reply to #188661)
Subject: RE: Heard On The Street Is A Lie
Exhaust yes, bags no.
bbrist
Posted 2016-08-31 5:15 AM (#188670 - in reply to #188661)
Subject: Re: Heard On The Street Is A Lie
Never took off exhaust just took out of lower bolt on shock and wheel came right out.
kin52
Posted 2016-08-31 7:23 AM (#188672 - in reply to #188661)
Louisville, KY
I've changed my rear tire three times and never removed the bags or exhaust once.
If you remove the link bolt that goes through the swing arm the rear wheel drops right down for removal. Both wheels can be removed from the bike in a half hour or less.
ljurgens
Posted 2016-08-31 2:44 PM (#188673 - in reply to #188661)
West Salem, WI United States
Same here, I removed the bolt on the Shock and dropped the swing arm down and the axle will slip right out!
Don07tncav
Posted 2016-08-31 3:55 PM (#188674 - in reply to #188661)
Yep. What Kin52and ljurgens said.
Posted 2016-08-31 4:55 PM (#188675 - in reply to #188661)
<p>yes the wheel can BUT not the belt The Vision's rear tire and belt can be changed WITHOUT removing the bags, you simply need a jack."</p><p> </p><p>he should of said ( the rear tire can be changed with out removing the bags)</p>
Edited by johnnyvision 2016-08-31 4:57 PM
Posted 2016-09-06 12:01 PM (#188772 - in reply to #188661)
I've done my rear tire at least 15 times and never removed bags or exhaust. Jack up, remove pushrod bolt, wheel is low enough to remove axle, take belt off of pulley and the wheel comes right out. Reverse to install. Confused over this post and it's meaning...
