Did the 6 hole/cut off end cap mod (exhaust)
Posted 2013-04-23 1:25 PM (#137432)
Subject: Did the 6 hole/cut off end cap mod (exhaust)
Finally persuaded myself to do the 6 each (1/2") hole mod on my 2011 Vision. I like the sound, nice and deep, not obnoxious; finally sounds like I have somewhat of a spark plug firing gasoline motor; as compared to the sewing machine sound of the unmodified stock mufflers.
Removed the chrome tailpipe end caps; removed the heat shields (easy since I have long ago cur the stock banding clamps and replaced them with large screw type radiator hose clamps) and then used a Sawzall (gingerly) to cut through the black end caps. Cut them suckers like butta...
Then used a 1/2" drill bit and easily drilled out 6 holes per side. reassembled it all and went for a ride. Sounds NICE...
Later today or this weekend, will play around with the Dobeck EJK and see if I can dial in a little more fuel... for a little stronger pull on acceleration.
Now need to buy some High-Temp black paint to see if I can "tighten up" the appearance of the pipes from the rear.....
Edited by willtill 2013-04-23 1:26 PM
XRsteve
Posted 2013-04-23 2:39 PM (#137433 - in reply to #137432)
Subject: Re: Did the 6 hole/cut off end cap mod (exhaust)
Georgia, west of Atlanta
I see "The MONSTER" parked to the left ................
Posted 2013-04-23 3:48 PM (#137438 - in reply to #137432)
Yes, the "Monster" and the Vision both co-exist peacefully with each other; in the shed.
I also have a beer refrigerator in the shed as well. Sort of like my little man cavelette
Edited by willtill 2013-04-23 3:48 PM
XRsteve
Posted 2013-04-23 4:30 PM (#137439 - in reply to #137432)
You think Carpenter would be interested in porting and big valving some Victory heads ?? From what I read, they are good at "improving" 4 valve heads from any motorcycle..............
Posted 2013-04-23 5:04 PM (#137440 - in reply to #137439)
XRsteve - 2013-04-23 5:30 PM
I'm not sure... he does a lot of head work on all types of bikes. Never heard him mention Victory nor have I seen a Victory in his shop.
Posted 2013-04-23 5:20 PM (#137442 - in reply to #137432)
I love my "Monster" have to share a pic of it... forgive me....
Edited by willtill 2013-04-23 5:21 PM
XRsteve
Posted 2013-04-24 3:44 PM (#137517 - in reply to #137432)
Looking good, and so does the dyno sheet I'm sure.............
Posted 2013-04-24 6:33 PM (#137531 - in reply to #137517)
XRsteve - 2013-04-24 4:44 PM
okie vision
Posted 2013-04-24 7:13 PM (#137542 - in reply to #137531)
Broken Arrow, OK
pimp....
