Removal of the O2 sensor's ..serious mutha's....
Posted 2013-04-16 6:35 PM (#134980)
Subject: Removal of the O2 sensor's ..serious mutha's....
Definitely a bitch to get cracked and loosened. I gave up for tonight; just have too many others things going on 'round here at the moment (like work).
Can't seem to get a 6 point 22mm on the rear one, and the front one won't budge. I need to heat the pipe (with the engine) and see if I can get the front to move... or it's penetrating oil time. I think I need to get a 12 point box wrench as well; there's just not enough room to get a 6 point wrench to bite.
You can look at them suckers and think it's easy to get to them but Ha ha ha ...it's a bitch; once you try to start putting a wrench on 'em.
Edited by willtill 2013-04-16 6:38 PM
okie vision
Posted 2013-04-16 6:40 PM (#134981 - in reply to #134980)
Subject: Re: Removal of the O2 sensor's ..serious mutha's....
Broken Arrow, OK
Sorry to hear that.
Mine were a piece O' cake. I do remember once I got the wrench on, I hit that sucker with a rubber mallet and they broke free easy.
The hardest part was getting to the zip ties on the front one to weave the wiring out. Keep at it!
Edited by okie vision 2013-04-16 6:42 PM
Posted 2013-04-16 6:44 PM (#134982 - in reply to #134981)
okie vision - 2013-04-16 7:40 PM
Sorry to hear that.
Ya, I CUT those zip ties and then replaced them afterwards. I'll work on it again tomorrow; I need to buy a 12 pt box end wrench.. Somewhere.
Vicbuilder
Posted 2013-04-16 8:33 PM (#134993 - in reply to #134980)
Subject: RE: Removal of the O2 sensor's ..serious mutha's....
The Vic Shop - Central Iowa
It seems like they are either stuck or they come right out.
If they are stuck get ready for a fight. I've found the best way is heat and lube. Heat the pipe moderately, then if you can get them to turn a bit work them in and out while blasting with penetrating oil. Don't try to just loosen. Loosen as much as possible, lube then turn it back in. Do this a dozen times and it SHOULD eventually work its way out. Worst case is it totally strips the sensor and you'll have to retap the pipe. Best case is it'll free up with a bunch of back and forth.
Posted 2013-04-16 9:04 PM (#134997 - in reply to #134980)
Thanks Rylan. Hopefully when I find a 12 pt 22mm I'll be able to get success at least with the rear one.
Vicbuilder
Posted 2013-04-16 9:06 PM (#134998 - in reply to #134997)
willtill - 2013-04-16 9:04 PM
I use a 7/8" wrench. When they are really stuck a 7/8" deep socket and breaker bar, but that is always followed by having to tap out the pipe.
Posted 2013-04-17 5:56 AM (#135012 - in reply to #134998)
Vicbuilder - 2013-04-16 10:06 PM
Eeak gads! I do not want to have to tap the bung hole.... Rylan.. when you have done this; were you just chasing the interior threads with the tap. or actually cutting a new interior thread size?
Monkeyman
Posted 2013-04-17 3:26 PM (#135056 - in reply to #135012)
Peru, IN
willtill - 2013-04-17 6:56 AM
The things you guys talk about! Freak.
Posted 2013-04-17 4:39 PM (#135059 - in reply to #135056)
Monkeyman - 2013-04-17 4:26 PM
Ha! Ya... that sounds odd when you read it.....
But......
GOT 'ER DUN !!!!!
Used some penetrating oil on the sensors, let it sit for 2 hours while I raced around on my DR650 looking for a offset 22mm 12pt wrench (found it) and then was able to get a good bite on the rear sensor; she came off with no difficulty.
The front one... well the damned offset wrench couldn't get a bite on it... so I tool Rylan's advice and used a 7/8's open end wrench; and got it to break loose too! Nice that I didn't destroy the O2's... so if I ever have to retrofit them; it won't be an issue.
Now I can't find any copper anti-seize for the bung plugs... do ya'll think regular anti-seize is OK in this area of heat?
baadawg
Posted 2013-04-17 5:53 PM (#135065 - in reply to #134980)
Chattanooga, TN
Where did you find the nuts for the bung holes? Seriously...
okie vision
Posted 2013-04-17 6:04 PM (#135066 - in reply to #134980)
Broken Arrow, OK
I just want to go on record, at no time during this thread did I ever type "bung hole", until now.
Posted 2013-04-17 6:13 PM (#135067 - in reply to #134980)
I got the "Bung hole" plugs from Jon at Witchdoctor's. They're like $13.65 a piece.
The "Bung hole" plugs did not come with gaskets though... i was expecting metallic ones' like the ones you see on spark plugs (and the O2 sensors have the same type of spark plug gasket as well btw...)
I have some Red High Temp RTV Permatex gasket maker that I am going to use sparingly on the flange of the bung hole plugs to ensure an adequate seal; not so much that it would be an issue to break them loose if necessary.
Still in a quandary about using regular silver anti-seize on the threads of the bung plugs; or maybe a trip to Pep Boys tomorrow is in order for the copper anti-seize stuff.
Edited by willtill 2013-04-17 6:18 PM
roundtwig
Posted 2013-04-17 6:15 PM (#135068 - in reply to #134980)
flagstaff, AZ
I think I missed the reason for the removal of sensors and then capping.
Posted 2013-04-17 6:25 PM (#135070 - in reply to #135068)
roundtwig - 2013-04-17 7:15 PM
Installed and running a Dobeck EFI jet Kit and Lloydz upper air filter. Need to disconnect and remove the O2's (removing O2's and plugging for a cleaner look on the head pipes) so that the O2's don't constantly fight the Dobeck's enriched fueling settings against what it's telling the ECU for stock map fueling at cruise.
Something like that.
Edited by willtill 2013-04-17 6:26 PM
okie vision
Posted 2013-04-17 6:27 PM (#135071 - in reply to #134980)
Broken Arrow, OK
you really didn't miss anything, Jeff.
It's a personal preference. When we install fuel tuners like the Power Commander or Dobeck, etc, the factory exhaust sensors get disconnected.
Since they're no longer used, I just preferred removing them and installing plugs for a cleaner look. Doesn't hurt a thing to leave them unhooked and in place.
Posted 2013-04-17 6:27 PM (#135072 - in reply to #134980)
you can pick this up at hardware store Liquid Wrench its the best thing you can have in the garage
okie vision
Posted 2013-04-17 6:29 PM (#135073 - in reply to #134980)
Broken Arrow, OK
I installed these
http://www.amazon.com/Vance-Hines-Sensor-Port-16925/dp/B0022ZT2PK/r...
Way to hang in there, Will!
Edited by okie vision 2013-04-17 6:30 PM
Monkeyman
Posted 2013-04-17 6:32 PM (#135075 - in reply to #135065)
Peru, IN
baadawg - 2013-04-17 6:53 PM
Rumor has it that Witchdoctor nuts are the correct size. (This thread has gone down hill...FAST.)
roundtwig
Posted 2013-04-17 6:48 PM (#135077 - in reply to #134980)
flagstaff, AZ
Thanks willtill and okie vision
baadawg
Posted 2013-04-17 7:18 PM (#135078 - in reply to #135075)
Chattanooga, TN
Monkeyman - 2013-04-17 7:32 PM
I'm leaving this one alone! I was thinking of asking for clarification. it almost seemed like you were saying that Witchdoctor's nuts were small enough to fit the bunghole properly. But I'm not going to since it is beneath me. The comment, not the bung hole. Well, anyways, crap. Y'all are a hoot!
Thanks for the heads up on the parts, I think I'll get rid of my O2 sensors as well since they aren't being used!
Edited by baadawg 2013-04-17 7:23 PM
Vicbuilder
Posted 2013-04-17 7:56 PM (#135079 - in reply to #135012)
willtill - 2013-04-17 5:56 AM
I have not yet ruined the threads on the pipe - yet. If the sensor is stuck and you have to force it out then you'll need a tap to remove the softer metal of the sensor that is left behind.
In other words, if your shaft is stuck in the bung hole, a bit of lube and a bunch of tugging should get it out. Ream out the hole to clean it up. Then get some bung plugs and plug up that open hole so your exhaust gas doesn't get out.
okie vision
Posted 2013-04-17 8:03 PM (#135080 - in reply to #134980)
Broken Arrow, OK
lmao, I've got freakin' tears in my eyes. Too much, lol
on a final note, i did not have much trouble at all inserting my plugs into the bung hole. It went very smoothly and I wouldn't hesitate to do it again!
opas ride
Posted 2013-04-17 8:48 PM (#135085 - in reply to #134980)
Is that with or without the Vaseline application?????.....This thread has gotten way out of whack!!!!
Monkeyman
Posted 2013-04-17 10:09 PM (#135092 - in reply to #135085)
Peru, IN
opas ride - 2013-04-17 9:48 PM
So, you're wanting to whack the bung hole? Or your saying there's a phone application to [determine the proper amount of] Vaseline used when screwing the nuts into the bung hole? Does it matter if you're off a little bit on the lube?
Monkeyman
Posted 2013-04-17 10:19 PM (#135093 - in reply to #134980)
Peru, IN
I just wanted to make it clear that willtill was the one who started the lubed up nuts in the bung hole discussion (post #7) although it's fairly obvious that, while he may be the lead freak, he's certainly not alone in his freakiness. There's lots of room in his freakdom. I'll bet Thanksgiving dinner is a hoot at your house, willtill. "Can you please pass the greased nuts, Grandma?" "How's your bung hole, Uncle Tim?"
