New Gloss Black Vision Rims
VisionNWRider
Posted 2008-12-20 1:34 PM (#25346)
Subject: New Gloss Black Vision Rims
Tri Cities, WA
Here is a picture of my new Gloss black Rims for my vision. I found them on e-bay for a kick butt price and won the auction. I think they will look real good on my Black new ride. I plan to send my stock rims on my bike now down to get chromed when i install these new bad boys. If I like them enough to keep them on it then i will if not then i will swap them out with the chrome ones when I need some new rubber.
Chuck
(BlackRims.jpg)
Attachments BlackRims.jpg (61KB - 2 downloads)
Chandler Tom
Posted 2008-12-20 1:40 PM (#25347 - in reply to #25346)
Subject: Re: New Gloss Black Vision Rims
Chandler, AZ
cool...
Trekwolf164
Posted 2008-12-20 2:35 PM (#25349 - in reply to #25346)
New York State
I can see buying a front rim but the rear seems like a waste of funds
Travelin Man
Posted 2008-12-20 2:44 PM (#25351 - in reply to #25346)
You got those from Randy's Cycles in Huntley, Illinois. I just purchased a similar set from him except that on mine they left the bead area of the rim the stock color with black everywhere else. It would be a great time to add a 90 degree valve stem, at least to the rear wheel.
Rebel
Posted 2008-12-20 4:20 PM (#25360 - in reply to #25349)
Linwood, MI
Trekwolf164 - 2008-12-20 2:35 PM
Not really. It all depends on how you have your bike set up. For instance, I'm, errr... well... a big, fat biker and I ride with a passenger a lot, so my rear shock is pumped up pretty far. This exposes a lot of the rear wheel, especially when on the stand. If ever got a different front rim, I'd definitely have to get a rear one to match.
devilboy
Posted 2008-12-20 4:21 PM (#25361 - in reply to #25351)
Central Florida
Travelin' Man - 2008-12-20 2:44 PM
DO NOT ADD 90 DEGREE VALVE STEM. IT CAUSED FLATS ON BOTH OF MY TIRES.
Centrifugal force causes stress to rubber part of valve stem and I had failures on both. Different angles and forces on auto tires....
front tire went first, had it towed to dealer.
1 month later rear went. I had my portable airpump and duct tape and was able to ride the 70 miles home by ductaping stem at angle where very little air leaked out. Every 20 miles or so I stopped and refilled tire. had a new valve stem put in after dealer inspected tire.
a word to the wise...................................
Edited by devilboy 2008-12-20 4:22 PM
Travelin Man
Posted 2008-12-20 6:15 PM (#25368 - in reply to #25361)
devilboy - 2008-12-20 3:21 PM Travelin' Man - 2008-12-20 2:44 PM You got those from Randy's Cycles in Huntley, Illinois. I just purchased a similar set from him except that on mine they left the bead area of the rim the stock color with black everywhere else. It would be a great time to add a 90 degree valve stem, at least to the rear wheel. DO NOT ADD 90 DEGREE VALVE STEM. IT CAUSED FLATS ON BOTH OF MY TIRES. Centrifugal force causes stress to rubber part of valve stem and I had failures on both. Different angles and forces on auto tires.... front tire went first, had it towed to dealer. 1 month later rear went. I had my portable airpump and duct tape and was able to ride the 70 miles home by ductaping stem at angle where very little air leaked out. Every 20 miles or so I stopped and refilled tire. had a new valve stem put in after dealer inspected tire. a word to the wise...................................
Your experience was out of the norm if you used a high quality valve stem.  I know of dozens of riders using the chromed steel 90 degree valve stems that have ridden millions, yes, millions of miles with absolutely no problem.  You must have used the cheap 90 degree valve stems that just "pop" into the rim opening, the good 90 degree valve stems have locking jam nuts on the inside that make it where the valve stem cannot flex and therefore the rubber cannot wear due to movement or as you call it "centrifugal force".  Here is a link to where I get mine from:
http://www.prestigewheel.com/Image2994.asp
Edited by Travelin' Man 2008-12-20 6:16 PM
devilboy
Posted 2008-12-20 6:40 PM (#25369 - in reply to #25368)
Central Florida
Travelin' Man - 2008-12-20 6:15 PM
I had them done at a professional non branded cycle shop. I guess they were either cheap or improperly installed.
Thanks for your info!
Lotzafun
Posted 2008-12-20 7:06 PM (#25372 - in reply to #25346)
Subject: RE: New Gloss Black Vision Rims
Rockford, IL
I seen these on Ebay. They are very sweet looking. And pretty much defintely the route I'm going with my Vision. However I'm debating a slight variation of solid black though. Not real sure what other type of look I might like, I'm thinking about some type of red or gray "accent" to them.
Kinda hate to risk hurting a bit of your sunshine here but I'm not so sure if I would say the price you paid was a "kick butt" price. Reason I say this is because when these were listed I checked with two local places that do powdercoating. They both quoted that it would run about $85.00 to $100.00 per wheel. After shipping you paid about $150.00 per wheel. But then again you did get bearings and spacers in your deal. Not sure what bearings and spacers run from Victory. And you also now have an extra set of wheels. So depending on which way its looked at you perhaps did get these wheels for a decent price. Who knows.....
Who are you going to have chrome your stock wheels? Happen to get a quote to do them yet? I've also slightly debated the chrome route but I think if I'm going to lay out $$$ for chrome I will probably go with a set of aftermarket wheels.
VisionNWRider
Posted 2008-12-20 9:10 PM (#25376 - in reply to #25351)
Tri Cities, WA
Travelin' Man - 2008-12-20 11:44 AM
Yeah I was thinking the same thing a 90 deg valve stem for them both. make life alittle eaiser i agree. Cant wait to mount them.
VisionNWRider
Posted 2008-12-20 9:19 PM (#25377 - in reply to #25372)
Tri Cities, WA
Lotzafun - 2008-12-20 4:06 PM
I am having my local dealer chrome them for me so where the send them to be done not sure but i think it's in cali some where., but not 100% sure. No quote yet. It's been snowing here so everything has kinda stoped at the moment. You are right it will be nice to have an axtra set of rims to try stuff with. After markets are spendy for sure, so I thought this would be good alternative for my bike with these Black rims I got for $324.00 to my door. Just can wait to mount these rims
kevinx
Posted 2008-12-20 10:05 PM (#25379 - in reply to #25372)
Lotzafun - 2008-12-20 7:06 PM
You forget that when powdercoating the bearings NEED to be replaced, and also the down time involved. Hell a pair of untouched STOCK wheels for $300 is a good deal
Lotzafun
Posted 2008-12-20 11:42 PM (#25381 - in reply to #25379)
Rockford, IL
VisionNWRider - 2008-12-20 8:19 PM I am having my local dealer chrome them for me so where the send them to be done not sure but i think it's in cali some where., but not 100% sure. No quote yet. It's been snowing here so everything has kinda stoped at the moment. You are right it will be nice to have an axtra set of rims to try stuff with. After markets are spendy for sure, so I thought this would be good alternative for my bike with these Black rims I got for $324.00 to my door. Just can wait to mount these rims
Why you going with the local dealer? I know you probably trust them and all...but why not cut out the proverbial "middle-man" and find a chrome shop yourself? Probably save a decent amount of dough. That is unless your dealer is cool enough to have you only pay invoice plus shipping, or perhaps a fair small mark-up. I mean...all the dealer is going to do is pack the wheels, call the chrome shop, ship the wheels, wait for them to get shipped back, call you and tell you they are in and collect the money from you. This doesn't take much of the dealers labor to do this, maybe 30-45 minutes total. I do believe in doing business with those who have treated you good in the past, loyalty is important. But....so is a $dollar$ too. Its a balance between loyalty and the $$$. I definetley would not automatically turn them over to a dealer without at least getting a quote from a chrome shop in the region so then you have something to compare with. But then again....its your wheels....so its your rules
Ask some local custom car guys. They will know any and all chrome shops in your whole region. They will know who is good bad and otherwise. Heck, might be a decent chrome shop within a short drive, save you some major shipping costs. As you have alread discovered...shipping two wheels one-way is pricey...imagine what shipping those two wheels round-trip is gonna run ya
kevinx - 2008-12-20 9:05 PM You forget that when powdercoating the bearings NEED to be replaced, and also the down time involved. Hell a pair of untouched STOCK wheels for $300 is a good deal
The bearings can't be R&I (remove/reinstalled)? They must be replaced? Any ballpark idea how much they run for each wheel?
BATMAN
Posted 2008-12-21 7:33 AM (#25384 - in reply to #25346)
MN.
I can't wait to see these on your bike. I am not a huge fan of the wheel itself, but have often wondered how they would look painted. Pics as soon as you can!
devilboy
Posted 2008-12-21 8:00 AM (#25386 - in reply to #25346)
Central Florida
I have had a black powder coated front wheel on for 10K. I think it looks great!
I havent done rear yet. We have no down time as far as weather so I am always reluctant to take bike out of service.
kevinx
Posted 2008-12-21 9:01 AM (#25388 - in reply to #25346)
"The bearings can't be R&I (remove/reinstalled)? They must be replaced? Any ballpark idea how much they run for each wheel?"
There isa no way to get the bearings out without damaging them. Realistically even if I could the cost of replacing the bearings is easily justified by the cost of potential failure. American, or Israeli bearings can be had for about $12 each. The Taiwan bearings used by Vic are about $20 each
VaParadox
Posted 2008-12-21 9:59 AM (#25390 - in reply to #25346)
Richmond, Virginia
Our dealer here did a really awesome blacked out wheel with the leading edge of each blade chromed I dont have any pics because the bike went out, but it was awesome between the chrome leading edge of the blade and the center cylinder being chrome.
VisionNWRider
Posted 2008-12-21 12:37 PM (#25394 - in reply to #25346)
Tri Cities, WA
I had my dealer look up what a stock replacement rim would be for our visions. They showed me the price and for what I paid for both of these black rims and shipping doesnt even cover the price of ONE stock rim from vic. So yeah I think I did well.
Hmm the reason I'm having my local dealer take care of the chroming is one they only charge me invoice plus shipping becasue they know they will get the service ticket to put them on for me so it's a win win for everyone. Plus I'm very loyal to those who take care of me and my vision. They are also sending down my stock Bezel/dash I took off to be blacked chromed and my rear tip overs to be chromed out of California. So I may just have them send everything at once to save on shipping cost. If we had a local chromer here I would go to them but we live in a smaller city so it' has to go out of the area to be done.
VisionNWRider
Posted 2008-12-21 12:39 PM (#25395 - in reply to #25386)
Tri Cities, WA
devilboy - 2008-12-21 5:00 AM
QUOTE]
Would love to see a pic of it on your bike????
devilboy
Posted 2008-12-21 11:15 PM (#25423 - in reply to #25395)
Central Florida
VisionNWRider - 2008-12-21 12:39 PM
Here you go!
(CIMG9320.jpg)
Attachments CIMG9320.jpg (38KB - 0 downloads)
RedRider
Posted 2008-12-22 6:11 AM (#25429 - in reply to #25346)
The black wheels look good. As long as you, the person that paid for them is happy with the price, that's all that matters.
Getting chrome done through your local dealer may be what's right for you. With all the stuff you have done to your bike he is most likely making it right for you. Kind of like when I have Advanced Plating in Nashville do my chrome and pay top dollar, of course they do top dollar chroming.
I hope to see your bike some day when it's all done but I have a feeling you will always find something more.
VisionNWRider
Posted 2008-12-22 12:04 PM (#25441 - in reply to #25346)
Tri Cities, WA
Thanks BlueOx. Your right I will always be doing some thing new to my ride. I love making it just mine. But there 's always a little voice in my head that says if I wanted to sell my ride would somebody want to buy it based on what I have done. My last ride went fast based on what i did to it so i always try and keep that in mind as well.
Devil boy thanks for hte image. i really like what you have done. I like the rotors black with red floating pins. I'm going for a black/chrome Red color look for my bike as well.
cw1115
Posted 2009-08-10 5:08 PM (#41308 - in reply to #25346)
Ruskin, Fl
Finally had the wheels powder coated black. Needed new rubber so it only made sense. $200 bucks and I had the pully and belt guard done too. I'll take some photos with a real camera soon.
(IMAGE_031.jpg)
Attachments IMAGE_031.jpg (42KB - 0 downloads)
Posted 2009-08-10 8:38 PM (#41312 - in reply to #25346)
Looks great! Someday my wheels will be black.
Ride Safe
Blue Demon
Posted 2009-08-11 12:15 AM (#41332 - in reply to #25346)
Kansas City, Ks
Really dig the black wheels!! It makes me wonder what the price of the Vision 8-ball's wheels will be?
