VFC3 settings with Cams, intake and exhaust
ScoreBo
Posted 2010-04-07 6:27 PM (#56902)
Subject: VFC3 settings with Cams, intake and exhaust
Northeast Ohio
I've been noticing lately that I get a fair amount of black smoke at wide open throttle with my setup. Kinda reminds me of a tractor pull. Bike runs great, just has all the characteristics of a rich running machine.
Anyways, I was hoping some of you fellow cammers would post your VFC3 settings so I can compare and contrast your settings to mine. I shot Lloyd an email last night, but didn't have time to follow up with a call today. KevinX, I shot you a PM too. All you have to do is mode thru each of the colors. Any help would be greatly appreciated.
Green - 4
Yellow - 4
Red - 7
Gr/Bl - 2.5
Y/Bl - 3.5
R/Bl - 1.5
I am thinking I need to raise my Red/Blue or lower Red.
Thanks again
Mudge
Posted 2010-04-07 8:00 PM (#56910 - in reply to #56902)
Subject: Re: VFC3 settings with Cams, intake and exhaust
20 miles west of Chicago.
S1L1 Map & Pipes, intake plate, cams.
G: 3.5
R: 5
Y: 3.5
GB: 5
YB: 6
RB: 3
kevinx
Posted 2010-04-07 8:55 PM (#56917 - in reply to #56902)
Assuming an S1 map
G-3
Y-3
R-2
GB-0
YB-5.5
RB-5.5
ScoreBo
Posted 2010-04-07 9:15 PM (#56920 - in reply to #56902)
Northeast Ohio
Stock map, no S1L1 card purchased.
kevinx
Posted 2010-04-07 9:20 PM (#56921 - in reply to #56920)
ScoreBo - 2010-04-07 10:15 PM
Y-4
R-6
Others the same
ScoreBo
Posted 2010-04-07 9:26 PM (#56922 - in reply to #56902)
Northeast Ohio
Interesting. Keep the RB at 1.5? Seems low, but I'll give it a try after this rain moves out of here.
ScoreBo
Posted 2010-04-07 9:32 PM (#56924 - in reply to #56902)
Northeast Ohio
Kevin, Yellow is currently at 4. Were you looking at Mudge's?
rwilly
Posted 2010-04-07 9:38 PM (#56925 - in reply to #56902)
seattle, wa
I got the cams and stage1 muffs.
My VFC settings are:
G-3
Y-3
R-3
G/B-off
Y/B-5
R/B-5.5
It POPS like a mofo and my fuel mileage is in the low 30s.
Edited by rwilly 2010-04-07 9:41 PM
ScoreBo
Posted 2010-04-07 9:39 PM (#56927 - in reply to #56902)
Northeast Ohio
rwilly, do you have the stock map on the ecu or stage 1?
rwilly
Posted 2010-04-07 9:42 PM (#56928 - in reply to #56902)
seattle, wa
Score, as far as I know I got the stage1 map.
ScoreBo
Posted 2010-04-07 9:54 PM (#56930 - in reply to #56902)
Northeast Ohio
Usually, when you buy the S1L1 setup you get a reflash card, mufflers and high-flow air filter. Since I was originally running Lloyds plate, VFC3 and Honkers, my dealer credited me the reflash card approximate value (since I didn't need it with the VFC3). Cams went in, VFC3 sent back for reprogramming to Lloyd and here we are.
kevinx
Posted 2010-04-08 6:04 AM (#56950 - in reply to #56922)
ScoreBo - 2010-04-07 10:26 PM
I have RB at 5.5 and NOT 1.5
kevinx
Posted 2010-04-08 6:06 AM (#56951 - in reply to #56924)
ScoreBo - 2010-04-07 10:32 PM
Those numbers reflect where I would be setting it with what you have. If one is the same as yours......It just means you had at least one right*LOL*
joe schmoe
Posted 2010-04-09 6:31 AM (#57043 - in reply to #56902)
Subject: RE: VFC3 settings with Cams, intake and exhaust
East TN
I am having the same problem as ScoreBo...
When I get on my Vision hard I look like a Deisel truck going down the road...BLACK SMOKE!!
1. How do you read the VFC3 controller and see the settings?
2. How do you adjust to the posted KevinX numbers?
3. KevinX did my cams and install in lovely Florida, would coming back to TN and change in elevation causing his settings from Florida to make it run rich in an higher altitude? (980' ASL)
Gas mileage is great I get right around 40 MPG and I don't ride SLOW...
charbin
Posted 2010-04-09 7:54 AM (#57055 - in reply to #56902)
Lavon, TX
John,
When KevinX said "others the same" he was referring to HIS earlier post - NOT to your original post.
Your R/Bl should be increased to 5.5
Just to be clear, the VFC3 settings for your equipment (S1L1 pipes but using stock base map and Lloyds Cams & Intake plate):
G-3
Y-4
R-6
GB-0
YB-5.5
RB-5.5
Bubba
Posted 2010-04-09 11:22 AM (#57077 - in reply to #57043)
joe schmoe - 2010-04-09 5:31 AM
When I get on my Vision hard I look like a Deisel truck going down the road...BLACK SMOKE!!?
1.?How do you read the VFC3 controller and see the settings??
Gas mileage is great?I get right around 40 MPG and I don't ride SLOW...
Joe, get the instructions here
http://www.quickvic-usa.com/instructions.asp
joe schmoe
Posted 2010-04-09 12:09 PM (#57084 - in reply to #57077)
East TN
Thank you very much....
ScoreBo
Posted 2010-04-09 12:22 PM (#57087 - in reply to #56902)
Northeast Ohio
Thanks Charbin. You are correct on my setup. Are you running a stock map too?
Joe Schmoe, That is probably what happened to me too. Lloyd thru it on the dyno in Daytona 2009. I am at 1100 feet here in Ohio.
Edited by ScoreBo 2010-04-09 12:24 PM
charbin
Posted 2010-04-09 12:42 PM (#57090 - in reply to #56902)
Lavon, TX
John - I have the S1L1 map. I dyno'ed locally back in Oct and was quite pleased with the KevinX performance results (posted in my sig).
My buddy commented the other day, however, that I was spewing black smoke on heavy throttle - and I am popping more now during shifting in the lower gears. Recently had the bike in the dealership for its 20K service - guess I need to check that my mechanic didn't modify any of Kevin's settings. Also looking at Lloyd's exhaust gasket set as well as his adjustable Idle Air Valve.
joe schmoe
Posted 2010-04-09 1:45 PM (#57098 - in reply to #57090)
East TN
charbin - 2010-04-09 1:42 PM John - I have the S1L1 map. I dyno'ed locally back in Oct and was quite pleased with the KevinX performance results (posted in my sig). My buddy commented the other day, however, that I was spewing black smoke on heavy throttle - and I am popping more now during shifting in the lower gears. Recently had the bike in the dealership for its 20K service - guess I need to check that my mechanic didn't modify any of Kevin's settings. Also looking at Lloyd's exhaust gasket set as well as his adjustable Idle Air Valve.
Yeah I think that both a good gasket set along with the IAV will go a long way in helping with the backfire issue...but NOT the black smoke
ScoreBo
Posted 2010-04-09 6:01 PM (#57110 - in reply to #56902)
Northeast Ohio
Charbin, you seem to be inline with other S1L1 mapped riders here. Changing when the main / RB from 1500 rpms to 5500 rpms might be too aggressive for my stock mapped bike. I am going to lower my Red a half point at a time until I get rid of the smoke. I am also going to see if I can get my bike into the Ducati store here and put it on their dynojet so I can measure my AFRs.
kevinx
Posted 2010-04-10 6:32 AM (#57142 - in reply to #57110)
ScoreBo - 2010-04-09 7:01 PM
You do NOT want to think of the RB setting as either 1500 or 5500 RPM. The adjustment is based on pulse width, and has little to do with RPM. Your biggest issues are that you are going to wot fueling WAY to early, and the sensativity is also WAY out of wack. The settings I gave you WILL work, and have proven themselves to be VERY close to ideal in most bikes with the same mapping.
Edited by kevinx 2010-04-10 6:36 AM
kevinx
Posted 2010-04-10 6:35 AM (#57143 - in reply to #57098)
joe schmoe - 2010-04-09 2:45 PM
Your ECM corrects for altitude, and some black smoke is not a worry. Remember these bikes operate best with a mixture in the 13.3 area, and that is pretty rich.
ScoreBo
Posted 2010-04-10 11:24 AM (#57157 - in reply to #57142)
Northeast Ohio
kevinx - 2010-04-10 6:32 AM
Kevin, just to be clear based on the posts with my stock mapped cammed setup:
G-3
Y-4
R-6
GB-0
YB-5.5
RB-5.5
kevinx
Posted 2010-04-10 8:45 PM (#57194 - in reply to #57157)
ScoreBo - 2010-04-10 12:24 PM
G-3
Y-4
R-6
GB-0
YB-5.5
RB-5.5
Ding Ding Ding...We have a winner*LOL*
