Load Equalizer problem.
LA Victory Rider
Posted 2012-01-25 6:17 PM (#106125)
Subject: Load Equalizer problem.
Monrovia, Ca
I replaced my front turn lights with LED's and installed the recommended load equalizers. The lights are blinking at the same rate they do without the equalizers. The equalizers are getting hot, so I assume they are doing what they are supposed to do.
Has anybody run into this issue?
LA Victory Rider
Posted 2012-01-25 8:58 PM (#106141 - in reply to #106125)
Subject: Re: Load Equalizer problem.
Monrovia, Ca
Got it figured out.
Posted 2012-01-26 2:59 PM (#106184 - in reply to #106125)
'splain it to us so we don't make the same mistake..
LA Victory Rider
Posted 2012-01-26 10:40 PM (#106210 - in reply to #106125)
Monrovia, Ca
Make sure you use a test light to connect to the blinking light wire and the ground.
