Left Heat grip rotating a bit
hawaii
Posted 2012-02-09 8:10 PM (#107351)
Subject: Left Heat grip rotating a bit
Hi guys
My left heated grip is rotating about 1/8" on the handle bar and driving me nuts. Just feels loose. Is there a way to tighten that up some how or that how they all are??
Thanks
Turk
Posted 2012-02-10 9:34 AM (#107373 - in reply to #107351)
Subject: RE: Left Heat grip rotating a bit
hawaii - 2012-02-09 8:10 PM
Hi guys
Thanks
There are two torx head screws that secure it to the bar. One or both is probably backed out. You have to roll back the rubber grip flange a little to get to the screws.
hawaii
Posted 2012-02-10 11:14 AM (#107385 - in reply to #107351)
Subject: Re: Left Heat grip rotating a bit
Hey thanks Turk! Which end should I roll back? Or both ends? Should I take off the end cap first?
Bad Horsie
Posted 2012-02-10 11:45 AM (#107387 - in reply to #107351)
Alberta
The flange to roll back is next to your thumb side, somewhere around the 11 o'clock and 5 o'clock postiion when looking from the bar end weight
Edited by Bad Horsie 2012-02-10 11:46 AM
Riverdawg
Posted 2012-02-10 12:21 PM (#107391 - in reply to #107351)
Camas Washington
Mine just started doing this. Will check to make sure it is screwed down tight.
Turk
Posted 2012-02-10 1:22 PM (#107399 - in reply to #107385)
hawaii - 2012-02-10 11:14 AM
The end nearest the clutch perch.
And, each of those 2 torx screws has a hole that it goes into, it doesn't just press against the outside of the bar.... so make sure it's properly lined up....
Edited by Turk 2012-02-10 1:23 PM
hawaii
Posted 2012-02-23 12:37 AM (#108361 - in reply to #107373)
Just wanted to thank Turk for the great advice! It was right on. No more wiggle in the grip.
Thanks again Turk!
