My HID Headlight won't work, Please Help
kodonnell1
Posted 2012-03-10 1:06 PM (#109709)
Subject: My HID Headlight won't work, Please Help
My hid light won't work when I switch it on. The high beam light on the dash works but the light dose'nt. Called the dealer and they said it would cost me $250.00 plus labor to fix it. I Thought all i would have to do is change out the bulb but they said it has it's own wireing harness and i could not just replace the bulb. I did check the fuze to make sure it was not blown, everything looks good but there are headlight relay boxes in the fuze area that i could not tell if they were good. Has anybody else ever have to replace the HID light and pay 250.00 just for the part or am I getting scammed by the dealer. They sell replacement bulbs for the low beams.why not the HID.
pollolittle
Posted 2012-03-10 1:14 PM (#109710 - in reply to #109709)
Subject: Re: My HID Headlight won't work, Please Help
Brighton, TN
I would check the switch connector. It is a press fit, nothing to keep it positively attached.. I had to take the connector off and push the terminals back out to make a positive connection. Mine became intermittent, flash on and off.
Trekwolf164
Posted 2012-03-10 1:15 PM (#109711 - in reply to #109709)
New York State
I have heard prices as much as $300. just for the HID bulb. I only use mine at night for that very reason. Changing it is a real chore from what I have read online you need small hands and patience two things I lack
Best of luck
kodonnell1
Posted 2012-03-10 1:33 PM (#109712 - in reply to #109710)
Could you tell me exactally where the switch connector is and i'll go out and check it now. Thanks for your help my friend.
cchristo
Posted 2012-03-10 4:15 PM (#109719 - in reply to #109712)
san antonio, tx
kodonnell1 - 2012-03-10 1:33 PM
They are on the bottom of the switch. You have to remove the guage bezel, then remove the console. Be careful when you are lifting up on the bezel so that you don't accidentally pull off any other wires from the switches.
Posted 2012-03-10 6:45 PM (#109730 - in reply to #109709)
Go buy a test meter. Then you can check relays and even unplug hid and see if there is power.
With out meter don't mess with any electoral stuff
atvtinker
Posted 2012-03-10 8:51 PM (#109741 - in reply to #109709)
Grand Cane, LA
You'll be hard pressed to get the HID light out without taking the fairing apart like the manual suggests. The bulb is held in with screws and the wires run all the way to the ballast. The bulb can be replaced without replacing the ballast as there is a connector at the ballast. It's a pain in the a** to get the connector undone without taking the ballast loose. I just replaced my main headlights with HIDs last year and I probably won't go back with regular bulbs again. Unbelievable how bright these are at night!
dan camarco
Posted 2012-03-10 10:08 PM (#109745 - in reply to #109709)
Lumber Bridge, NC United States
If you are talking about the center light which they call the hid light I replaced mine from the dealer same part number as in the bike for 12 dollars and change. and you can do it yourself. remove the airfilter and unclip it. it pops out, then put a meter on the bulb and see if it is blown.
hulign
Posted 2012-03-10 10:54 PM (#109748 - in reply to #109709)
Subject: RE: My HID Headlight won't work, Please Help
First off HID lights use high voltage. I wouldn't go poking around with a meter or test light. You can test the low side to make sure you have power but thats about it. After that it runs on magic smoke (dont let the magic smoke out of anything! It's expensive and you can't put it back). Second if the light or ballast died on mine outside of warranty I would see about getting an aftermarket set. I have been running a set on my truck for 3 years now that I paid 50.00 for the bulbs and ballasts. I doubt the reflector is changed so find a kit that fits the non hid Vision bulb number.
Good luck!
hulign
Posted 2012-03-10 10:57 PM (#109749 - in reply to #109745)
dan camarco - 2012-03-10 10:08 PM
I don't think this was an HID setup. The HID bulbs are crazy expensive.
