fuel pump whistle
jimtom
Posted 2013-01-02 5:44 PM (#129085)
Subject: fuel pump whistle
Sand Rock, AL United States
started making a whistling sound today as it primed up. it's an 08 with 40,500 on it. Is this something to be concerned about? it started and ran fine all day.
Posted 2013-01-02 5:55 PM (#129087 - in reply to #129085)
Subject: Re: fuel pump whistle
maybe your gas cap is not tight or the gasket is bad.
If it was the pump whistling you would have a air leak and bike wouldn't run right.
So look at the cap
jimtom
Posted 2013-01-02 6:18 PM (#129089 - in reply to #129087)
its an 08 vision , i put the cap on the same way. it started the noise this morning but it has started without this noise several times since I last put gas in it.
jimtom
Posted 2013-01-03 5:14 AM (#129108 - in reply to #129089)
and it's more of a squeel/squack
wingit3611
Posted 2013-01-03 3:22 PM (#129113 - in reply to #129085)
The gas cap being on, off or not tieght would have no effect. the tank is vented and does not build up pressure.
Posted 2013-01-03 5:25 PM (#129119 - in reply to #129085)
the gas cap is vented. Air goes to the highest point
Edited by johnnyvision 2013-01-03 5:25 PM
jeffmack
Posted 2013-01-03 9:25 PM (#129129 - in reply to #129085)
Mine did the same thing. I was told it was a " impending bypass" and was replace 4 years into my 5 year warranty. Good luck
jimtom
Posted 2013-01-04 11:47 AM (#129146 - in reply to #129129)
I called my dealer. My bike is warrentied through July 2014. They said they could replace it when it fails.
jeffmack
Posted 2013-01-04 12:41 PM (#129150 - in reply to #129085)
When???? How bout in front of a semi while merging? Or pulling thru a tight turn? Dangerous. It will fail, don't wait for it too. Just my humble.
jimtom
Posted 2013-01-04 12:48 PM (#129151 - in reply to #129150)
what the service manager said was that they can't replace it under warranty until it fails.
Joker
Posted 2013-01-04 2:57 PM (#129154 - in reply to #129085)
Buford, GA United States
Mine started doing it a couple of months ago. I had the dealer look and listen to it but as long as it is working the warranty will not cover it. My O8 warranty expired on December 7 so I am out of luck if it totally fails. Mine has almost 61,000 miles on it
jeffmack
Posted 2013-01-04 8:22 PM (#129169 - in reply to #129085)
Hmmmm I must have gotten lucky. Written up as a impending bypass was covered. Maybe request ur shop to submit with that verbage. Just a guess.
Double Vision
Posted 2013-01-04 9:01 PM (#129171 - in reply to #129085)
My 08 Vision just started making that noise too.
