CCT Trunk Removal
Terry Hills
Posted 2013-06-14 4:35 PM (#140482)
Subject: CCT Trunk Removal
Ok I will admit I am a dummy, tried to remove my trunk from the CCT today for the first time and everything works great except... I can't get the electrical plug through the small space between the saddlebag bracket/fender & seat.. I turned it as many different ways as I could and it still would not easily come through the space so I could separate the trunk from the bike. What am I missing?
Roadrocket
Posted 2013-06-20 4:47 PM (#140722 - in reply to #140482)
Subject: RE: CCT Trunk Removal
B'ham, Al.
 Ever get it out?? No problem with mine going or coming. Been a while since I took it off and I don't recall exactly how/where it came thru.
Sorry, RR
hclare
Posted 2013-06-20 5:55 PM (#140725 - in reply to #140482)
Subject: Re: CCT Trunk Removal
My limited experience is that you have to remove the seat. I'd like to know if there's an easier way as well.
pfhague
Posted 2013-06-20 8:02 PM (#140727 - in reply to #140482)
If I remember from when I did mine, Squeeze the plastic loom that is over the wires and slide it through the should fit through ok. No need to remove the seat.
hclare
Posted 2013-06-21 6:01 AM (#140736 - in reply to #140727)
pfhague - 2013-06-20 8:02 PM
I believe the issue is the size of the plug.
Terry Hills
Posted 2013-06-21 5:54 PM (#140755 - in reply to #140482)
I think I am going to back to the dealership and have the salesman take the trunk off the floor model for me since he said it was a snap.
hclare
Posted 2013-07-14 1:19 PM (#141602 - in reply to #140755)
pfhague had it right. I looked at mine while cleaning it this morning and saw that the harness was routed between the fender and saddlebag bracket, behind the forward standoff. I managed to get the harness out by removing the saddlebag attaching clip. I then rerouted the harness forward of the standoff. With the side panel removed, the seat will flex enough to slide the harness between it and the chrome bracket. I'll try to post a picture if needed.
shelmberger
Posted 2013-07-18 11:27 AM (#141798 - in reply to #140482)
No need to remove seat or anything else. All you have to do is slide the wire loom between seat seat and the bracket.
