Front Fender Crack - Front Section
lennyb
Posted 2014-08-04 7:41 PM (#163968)
Subject: Front Fender Crack - Front Section
Perry Hall, MD
Started hearing a light snapping sound when I apply the front brake. Started looking for the cause and found a crack in the front (painted) section of the front fender. About 1/2" long running up from the upper left mounting bolt. My repair to a similar problem with the rear section appears to be holding up fine. Heading out in 2 days for 2500 mile ride with no time to repair it before I leave.
jeffmack
Posted 2014-08-04 7:56 PM (#163969 - in reply to #163968)
Subject: Re: Front Fender Crack - Front Section
Very thin coat of clear acrylic nail polish will get you thru the trip easy and will never be seen. Ride safe
buzz64077
Posted 2014-08-05 12:28 PM (#163986 - in reply to #163969)
orrick, mo
Try just removing the whole fender and riding. Thats what I did when mine broke and I was out on the road. There wasn't any adverse affects on handling. I've since installed a Drag Specialties tire hugger series fender.
I just had to make some spacers to get the new fender to fit.
lennyb
Posted 2014-08-05 4:58 PM (#163996 - in reply to #163968)
Perry Hall, MD
Thanks for the reminder on the nail polish temporary repair.
Will probably end up looking at the fender replacement options. Could end up on the Christmas wish list.
Posted 2014-08-05 7:06 PM (#163997 - in reply to #163968)
big round flat washer will hold it in place all so
lennyb
Posted 2014-08-06 7:44 PM (#164020 - in reply to #163997)
Perry Hall, MD
Washer isn't an option since the aux. driving lights use the same mounting bolts, but thanks.
Leaving tomorrow for Minnesota - watch for the Baltimore Raven wedges.
Riverdawg
Posted 2014-08-07 2:27 PM (#164049 - in reply to #163968)
Camas Washington
So you have aux driving lights installed where the crack is. Makes me think you over tighten which lead to the crack.
