Zumo 550 on Cross Country Tour
Slappy
Posted 2014-12-07 9:48 AM (#169019)
Subject: Zumo 550 on Cross Country Tour
Just integrated my 550 to the Cross audio system by building the male end of the unused grey capped audio line inside the fairing (looking in on right below the HID ballast). Rather than buy & hack the $140.00 Victory GPS integration cable I built one, costing an hours time installed for all of $16.00 including a new 3 foot audio line 3.5mm to RCA. The RCA ends are cut off and wired into the plug I got from Digikey.com I did not need power through this connection so just used the 3 audio input lines.
Set up works great getting NAV through the system speakers during interrupt of other audio and the mp3 tracks stored in the 550 play through in stereo.
Be sure to order a few extra pins as they are very small and tough to solder / work with
Attached is PDF file of Digikey part numbers and wiring diagram I used.
Connector Housing Digikey # 455-1190-ND mfg p/n 05T-JWPF-HHLE-D
male Connector Terminal tabs Digikey # 455-1320-1-ND mfg p/n SWPT-001T-P025
Attachments NAV wires001.pdf (114KB - 11 downloads)
