vision accessory power supplies
mdhass
Posted 2008-09-30 11:17 PM (#19397)
Subject: vision accessory power supplies
I was just wondering if anybody knows of any accessory power supplies on the Vision that would be easy to access and use, rather than connecting directly to the battery. I am looking into adding some LED's.
bigwill5150
Posted 2008-10-01 2:40 AM (#19408 - in reply to #19397)
Subject: Re: vision accessory power supplies
Reno County, KS
Yes, under the panel that lifts off directly behind the fuel tank is an open harness that is accessory switched. I found it with a multimeter and use it for my LEDs. It's an easy grey plug to find with one black wire and one grey/pink stripe wire for +. A blade type splice connector will fit into the +/- slots on the open harness and a little electrical tape to keep them insulated and secured does the trick. I found a plug that fits at Radio Shack, so I was able to solder everything onto the new plug and then connect it. I would recommend a powerswitch somewhere for your LED's so that you can turn them off if the cops have a problem. That's usally only the case if you're using red or blue (mine are blue and I've been warned in California). Mine is right at the harness under the panel, so I have to lift the trim panel to get to it but it's out of sight. Hope this helped.
-Will
mdhass
Posted 2008-10-01 11:50 AM (#19456 - in reply to #19397)
Thank you very much for the info, I will look for it tonight.
