Victory vision randomly shutting off
frederick
Posted 2015-09-09 12:34 PM (#174743)
Subject: Victory vision randomly shutting off
Temperature 95 riding down a road bike shut off. About one minute later the fuel pump came on and it started up again. Road for about half mile shut off. Again waited about a minute during that minute it would not crank over the ABS light was on but the start which was not working. I removed and jumped the two wires at the circuit breaker next the battery bike started ran for about a mile died. It didn't matter if I was going straight or taking turns it would shut off about every mile or two. Switch relays checked fuses now I'm reading something about the tip over sensor. I don't want to just start changing parts relays fuses etc. etc. etc. Any suggestions would be appreciated.
2013 victory vision tour
Posted 2015-09-09 2:19 PM (#174745 - in reply to #174743)
Subject: Re: Victory vision randomly shutting off
I'm guessing it may be in the kill switch or ignition switch.
Posted 2015-09-10 5:56 PM (#174767 - in reply to #174743)
do a fuel pump test. Go to auto store rent a tester. Pull right hand cheese wedge. You'll see a black cap like a valve stem cap. Unscrew it screw in tester. Turn on key and crank motor over. You should get 49 psi less pump is bad. Test a couple times
https://www.youtube.com/watch?v=CCOJWC2Xrs8
frederick
Posted 2015-09-11 11:38 AM (#174776 - in reply to #174743)
Thank you very much for all the information. I tested the fuel system electrical fuel pump output and pressure all in good working order. Tested the coils electrical ignition system ignition switch. Went to my local dealer talk to the mechanic that works on the visions he said that tip over sensor was my last option not including wiring harness inspections. Not sure where the tip over sensor is at he said it's behind the front fairing.
2013 victory vision
black
Been riding for 30 years first vision love it
Been a mechanic for 30 years hate it ha ha
When I finish the repairs I will update this page and report what I find thanks again everybody have a great day.
Posted 2015-09-11 3:31 PM (#174778 - in reply to #174743)
http://parts.polarisind.com/images/VIC/SWITCHES/13VN1.gif
i guess it looks like this? http://www.ebay.com/itm/Polaris-Victory-Vision-Tip-Over-Bank-Angle-...
Edited by Arkainzeye 2015-09-11 3:34 PM
lennyb
Posted 2015-09-12 4:49 PM (#174784 - in reply to #174743)
Perry Hall, MD
check battery and cable connections as well - symptoms I experienced on one trip were engine died a couple of times when I would let it idle - new battery was the solution
Posted 2015-09-13 5:37 PM (#174794 - in reply to #174743)
In behind the left cheese wedge is a tep sensor unit $59.99
(Image.gif)
Attachments Image.gif (28KB - 1 downloads)
Posted 2015-09-13 5:43 PM (#174795 - in reply to #174743)
TMAP sensor
pkohlstedt
Posted 2016-01-15 9:00 PM (#177243 - in reply to #174743)
Subject: RE: Victory vision randomly shutting off
, AZ
Ever get a solution ? mines in the shop with the same problem
Posted 2016-01-16 5:26 PM (#177254 - in reply to #174743)
could be bad connection at the switch under pannel
atvtinker
Posted 2016-01-18 3:47 PM (#177272 - in reply to #174743)
Grand Cane, LA
Had the same problem with the '08 Vision I had and it turned out to be the kill switch. Had to take it apart and clean out the corrosion that got on the contacts. It happened on one of my long trips, but once I cleaned it, it never happened again. Be sure to coat everything with electrical grease once you get it cleaned. I guess the constant washing around the handlebars lets water into the switch which corrodes the copper contacts inside the switch and shorts it out.
