Vision MOD: AMPS, 6 1/2's, 5 1/4's, 8" subs (It keeps coming up)
icemann
Posted 2015-09-19 8:45 PM (#174871)
Subject: Vision MOD: AMPS, 6 1/2's, 5 1/4's, 8" subs (It keeps coming up)
, OH
WIRING COLORS, HOW TO, SPEAKERS, AMPS, ETC ~ HOPE IT HELPS
This can easily be done on the bike.
Adding Rockford Fosgate T400 x4ad 400watt 4 ch amp, and (2) Rockford Fosgate T400 x2ad 400watt 2ch amp
(2) 6 1/2's for the front (Fosgates)
(2) 5 1/4's for the rear (Fosgates)
(2) 8" marine grade subs to the rear bags.
(4) Tweeters
And a bunch of other's while it is nakid. over 1200 watts Clean
1) On the left side on top of the gas tank. I am currently installing a rockford fosgate T400x4ad micro 400 watt 4 channel amp. The amp is incredibly small. 8-5/16"W x 1-15/8"H x 4-1/4"D.
The amp allows high level inputs that also double as remote turn leads on for the amp.
The front factory speaker wires can be removed from the front speakers and rerouted back to and connected to the front input of the gas tank mounted amp. Run new wires out of the amp back to the fronts speakers.
VISION- Speaker wires located under console. The big plug coming out of the radio. -
Left Front Speaker Positive - Brown/Red
Left Front Speaker Negative - Brown/Black
Right Front Speaker Positive - Gray/Red
Right Front Speaker Negative - Gray/White
Left Rear Speaker Positive - Orange/Red
Left Rear Speaker Negative - Orange/Black
Right Rear Speaker Positive - Pink/Red
Right Rear Speaker Negative - Pink/Black
2) I replaced the front factory 5 1/4 speakers with Rockford Fosgate T165, 6 1/2 two way speakers.
On the speaker itself, Minor trim work, on the metal housing between two of the mount holes, was needed. This is done so the speaker will fit the factory mount holes and the factory speaker grill fits just fine with the curve around the bezel sides.
Remove the plastic speaker box's for the fronts no longer needed. The speakers bolt right to the factory speaker mount holes using nuts and bolts instead of screwing into the speaker boxes.
The factory round circle opening for the factory 5 1/4 speaker needs to be made bigger. The opening on the stock speaker mount needed to be made slightly more open to accommodate the diameter of the 6 1/2's. just making the round opening bigger with a dermal to allow the woofer to move without touching plastic. Bolt holes still line up. DONT CUT OFF BOLT HOLES.
I ran a four conductor wire from the gas tank mounted amps inputs all the way back to the left saddle bag. Then over to the right saddle bag. (These will serve as high level, piggy backed inputs, for the 2nd & 3rd amp as well, which is located in the left/right bags). same inputs for both amps. (It's only signal and remote turn on).
FOSGATE AMPS HAVE HIGH INPUT BUILT IN AS WELL AS INPUT AND OUTPUT ADJUSTMENTS. Converter not needed.
First. Size perspective stock to 6 1/2's
Minor cuts needed on speaker itself to fit stock space
One CUT to line up in STOCK LOCATION - LINE UP CUTS ON SPEAKER
RIM 1/8" around the circle to make 5 1/4 to 6 1/2 cutting off to ALLOW ROOM FOR THE CONE TO MOVE
AMP ON LEFT GAS TANK AS USUAL. 2nd amp in left bag. 3rd amp in right bag
FUSE BLOCK FOR ACCESSORIES IN LEFT BAG XM MOUNT HOLE. NICE ADD ON EASY REACH
all accessories run on this
WIRE LOOM EVERYTHING FRONT TO REAR neatness counts.
THE REARS. 5 1/4 stock location. plug n play. (new wires to amp)
8" SUBS now HERTZ
BLUE TOOTH KEY BOARD MEDIA CONTROLLER
Satechi, the BT Button Series / Built my own phone holder
FINISHED
Edited by icemann 2015-09-19 9:00 PM
(9016-64253c09c8e53de99c3f7f26752d3517.jpg)
(fb_img_1441416734837-jpg.8898.jpg)
(fb_img_1441416706403-jpg.8897.jpg)
(fb_img_1441416660565-jpg.8893.jpg)
(fb_img_1441416680818-jpg.8896.jpg)
(fb_img_1441416676622-jpg.8895.jpg)
(2014-10-11-16-22-46-jpg.612.jpg)
(fb_img_1441416671535-jpg.8894.jpg)
(10559744_10154538478725157_397261810525945387_n.jpg)
(2014-09-18-14-38-30-jpg.144.jpg)
(10608357_10154538489000157_7715524772955963487_o.jpg)
(1537735_10154582937460157_7058338203297818895_o-jpg.9026.jpg)
(get-attachment1.asp.jpg)
(10633475_10154583195815157_173529997202369322_o.jpg)
(10557530_10154583195580157_6182854383847665617_o.jpg)
(1522220_10154583194805157_9000530901206432416_n.jpg)
(10560282_10154538485850157_977521078565277986_o.jpg)
(10453037_10154538486395157_1118960213626213210_o.jpg)
(20150513_125040-jpg.5503.jpg)
(get-attachment.asp.jpg)
(get-attachment2.asp.jpg)
(20150513_190126-jpg.5507.jpg)
(20150513_144735-jpg.5506.jpg)
(img_20150514_071352-jpg-5483-jpg.9041.jpg)
(img_20150610_230405-jpg-6518-jpg.9040.jpg)
(rapture-8-jpg.9033.jpg)
(rapture-1-jpg.9034.jpg)
(rapture-6-jpg.9035.jpg)
Attachments 9016-64253c09c8e53de99c3f7f26752d3517.jpg (15KB - 8 downloads)
Attachments fb_img_1441416734837-jpg.8898.jpg (88KB - 4 downloads)
Attachments fb_img_1441416706403-jpg.8897.jpg (46KB - 3 downloads)
Attachments fb_img_1441416660565-jpg.8893.jpg (40KB - 3 downloads)
Attachments fb_img_1441416680818-jpg.8896.jpg (31KB - 2 downloads)
Attachments fb_img_1441416676622-jpg.8895.jpg (36KB - 4 downloads)
Attachments 2014-10-11-16-22-46-jpg.612.jpg (55KB - 2 downloads)
Attachments fb_img_1441416671535-jpg.8894.jpg (24KB - 2 downloads)
Attachments 10559744_10154538478725157_397261810525945387_n.jpg (14KB - 4 downloads)
Attachments 2014-09-18-14-38-30-jpg.144.jpg (51KB - 2 downloads)
Attachments 10608357_10154538489000157_7715524772955963487_o.jpg (43KB - 4 downloads)
Attachments 1537735_10154582937460157_7058338203297818895_o-jpg.9026.jpg (64KB - 2 downloads)
Attachments get-attachment1.asp.jpg (59KB - 3 downloads)
Attachments 10633475_10154583195815157_173529997202369322_o.jpg (26KB - 3 downloads)
Attachments 10557530_10154583195580157_6182854383847665617_o.jpg (43KB - 2 downloads)
Attachments 1522220_10154583194805157_9000530901206432416_n.jpg (18KB - 2 downloads)
Attachments 10560282_10154538485850157_977521078565277986_o.jpg (60KB - 2 downloads)
Attachments 10453037_10154538486395157_1118960213626213210_o.jpg (33KB - 2 downloads)
Attachments 20150513_125040-jpg.5503.jpg (50KB - 2 downloads)
Attachments get-attachment.asp.jpg (66KB - 2 downloads)
Attachments get-attachment2.asp.jpg (76KB - 2 downloads)
Attachments 20150513_190126-jpg.5507.jpg (42KB - 2 downloads)
Attachments 20150513_144735-jpg.5506.jpg (51KB - 2 downloads)
Attachments img_20150514_071352-jpg-5483-jpg.9041.jpg (53KB - 2 downloads)
Attachments img_20150610_230405-jpg-6518-jpg.9040.jpg (59KB - 2 downloads)
Attachments rapture-8-jpg.9033.jpg (237KB - 3 downloads)
Attachments rapture-1-jpg.9034.jpg (104KB - 3 downloads)
Attachments rapture-6-jpg.9035.jpg (70KB - 4 downloads)
icemann
Posted 2015-09-19 9:02 PM (#174873 - in reply to #174871)
Subject: Re: Vision MOD: AMPS, 6 1/2's, 5 1/4's, 8" subs (It keeps coming up)
, OH
HOPE IT HELPS SOMEONE. 1200 Available watts clean
Posted 2015-09-20 9:03 AM (#174874 - in reply to #174871)
even though its more than i want to do.. i respect the hell out of what you did.. and it really says a lot about you that you took the time to break it down for us all.. and if the time comes for me to do this.. im dropping my vision off at your house !! LOL im right in pittsburgh...
jimtom
Posted 2015-09-21 5:53 AM (#174888 - in reply to #174873)
Sand Rock, AL United States
WOW!
MaxAlexand
Posted 2015-09-21 11:07 AM (#174891 - in reply to #174871)
Great write up w/pics!
Thank you!
Posted 2015-09-29 2:58 PM (#175225 - in reply to #174871)
iceman - Why the two different subwoofer styles?
icemann
Posted 2017-04-18 8:06 PM (#191752 - in reply to #174871)
Subject: RE: Vision MOD: AMPS, 6 1/2's, 5 1/4's, 8" subs (It keeps coming up)
, OH
One is a mid base (the JL Audio) the other is a sub with a tweater, and midrange on a bridge on the woofer itself. Running twin 8's per side (at the time).
JD
Posted 2017-07-08 11:31 PM (#192084 - in reply to #174871)
Fantastic!
Killa khonsu PSMC
Posted 2017-07-16 2:26 PM (#192105 - in reply to #174871)
How did you make your 8" wooden speaker rings?
icemann
Posted 2017-07-17 9:58 PM (#192107 - in reply to #192105)
, OH
It's band saw cut out. Similar to making a spacer for speaker mounts old school. Draw a circle on board cut it out on a band or scroll saw.
I cant remember however I think the 1st layer is 1/2 inch thick piece of wood. I think the 2nd layer is 3/4". Basically I needed to bring the recessed or offset portion of plastic upper level with the bottom. (top 1/2 of the bag wall to be flush with the bottom 1/2 of the bag wall)
Then the 2nd layer was glued to the first layer to give a flat mounting ring to mount the speaker on. The 3rd level was just thick enough so the tweeter wouldn't bottom out if the bike flexed, leaned etc. Then drilled thru all pieces of wood into the plastic on the bike. Then drilled out the plastic to make it look like a grill so air and sound could escape.
Then used alum inserts into the plastic that expand when the screw is tightened into it. PRESS those into the hole on the bike, then run a long screw thru the speaker which is up against the wood spacer, and thru all of that into the metal inserts pressed into the plastic.
(1GNL2_AS01.jpg)
Attachments 1GNL2_AS01.jpg (82KB - 0 downloads)
victoryvisiontour
Posted 2017-08-19 2:49 PM (#192171 - in reply to #174871)
Nice craftsmanship, icemann.
killerx
Posted 2017-08-20 9:10 AM (#192175 - in reply to #174871)
Nice write up!
