sirius sat radio
racershawn
Posted 2009-03-04 10:43 PM (#29550 - in reply to #29546)
Subject: Re: sirius sat radio
Hampton Va
that is for kenwood radios
Posted 2009-03-05 7:00 AM (#29567 - in reply to #29352)
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/Stor...
look at where the antenna is and mounts.. neat. i know our handlebars are goofy, but im going to order this and try to make it work anyways, as i want to be able to change the stations (with in reach of my arm). if it doesnt work, then no biggie. i could at least use the power supply it comes with. I thought the antenna was nice. No tons of cable to wrap up and hide.
Edited by Arkainzeye 2009-03-05 7:03 AM
spursmvp
Posted 2009-03-05 7:52 AM (#29570 - in reply to #29567)
O'Neill, Nebraska
Arkainzeye - 2009-03-05 6:00 AM
This looks cool, but I think our handlebars are bigger than 1" so how do you think we could mount it?
Posted 2009-03-06 6:35 AM (#29637 - in reply to #29352)
the motorcycle mount did not fit on the handlebars. (knew that) but im going to try my ram mount.. I dont have a problem with putting it in my glove box. BUT i want to be able to read the display and by able to change radio stations without all kinds of effort...
spursmvp
Posted 2009-03-08 12:58 AM (#29777 - in reply to #29352)
O'Neill, Nebraska
I found a RAM handlebar mount on ebay for about $45 that will fit a 1 1/2" handlebar like that on our bikes. I then went to the RAM website and bought the extensions and mounting parts for my Sirius Sportster. There is now a Sirius hard wire kit that allows us to tap into the antennae plug so we don't have to use the FM modulator....this gives better sound while allowing use to control the volume via the handlebar.
I also purchased the Sirus hardwire kit so the electrical portion will be hard wired and the sound output will go directly to the radio. So far I've spent about $125 on all of the pieces (not counting the Sirius Sportster that I already had). Still a bunch less than the XM set up and I will be able to change channels on the satellite tuner because it will be mounted on the handlebar.
Once everything has come in and I've complted the install I'll forward pictures of the final product. I think it will work great and look very professional.
spursmvp
Posted 2009-03-15 8:16 PM (#30270 - in reply to #29352)
O'Neill, Nebraska
Here is the link to the other Vision Riders thread where I've posted the photos for the installed product. The wires run down the handle bar and everything tucks nicely underneath the console. Looks pretty good!
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2883&pos...
babyboov92c
Posted 2009-03-20 10:41 AM (#30573 - in reply to #29352)
Subject: RE: sirius sat radio
Bar Hopper
I have mounted a Sirius starmate 4 where the GPS should go .I couldn't be happier with it.But I would like to wire it so that the power cuts off with key.By the way this deal I done is great.Best and cheapest thing I could have done For my tunes.If theirs any interest Ill be glad to post and add pix.
babyboov92c
Posted 2009-03-20 10:44 AM (#30574 - in reply to #29352)
Going to try some pix again.
babyboov92c
Posted 2009-03-20 10:45 AM (#30575 - in reply to #29352)
KansasGuardsman
Posted 2009-03-20 2:19 PM (#30582 - in reply to #29352)
Wichita, Kansas
The easiest place is under the tank cover, or under the console, depending on how the harness was laid in. There are two grey connectors for the optional powerlets. The terminals take 1/4" male flag connectors and power is switched with the ignition. Grey/Pink is power, black is ground. No cutting required!
KansasGuardsman
Posted 2009-03-20 2:20 PM (#30583 - in reply to #29352)
Wichita, Kansas
Double post
Edited by KansasGuardsman 2009-03-20 2:21 PM
KansasGuardsman
Posted 2009-03-20 2:20 PM (#30584 - in reply to #29352)
Wichita, Kansas
Double post
Edited by KansasGuardsman 2009-03-20 2:22 PM
KansasGuardsman
Posted 2009-03-20 2:20 PM (#30585 - in reply to #29352)
Wichita, Kansas
Double post - now I see how this happens. When the system gives an error when you reply, it actually posts anyway!! No need to do it again. Live and learn, eh?
Edited by KansasGuardsman 2009-03-20 2:23 PM
Long_Will
Posted 2009-03-29 10:35 AM (#31190 - in reply to #29352)
Quincy Massachusetts
I did this the first day I had the bike - October 2007. Use the power connector in the left glovebox - will power off with the ignition.
(Vision-Sat-Radio.jpg)
Attachments Vision-Sat-Radio.jpg (57KB - 5 downloads)
spursmvp
Posted 2009-03-29 12:46 PM (#31200 - in reply to #29352)
O'Neill, Nebraska
Not bad if you don't have a GPS. Good work.
