XM Radio...
ElroyJ
Posted 2009-06-15 4:53 PM (#36777)
Subject: XM Radio...
Centennial, CO
Ok...I am sure this is probably the stooooopidest question(s) I can ask but hey...how do you get an answer if you don't ask?
I purchased the CB unit and have thought long and hard about XM.
1. Will it fit in the trunk with the CB already there?
2. This is a high price to pay for something that I can mount on a handlebar for 100 bucks OR less. Is the trunk version worth my time?
wrr1home
Posted 2009-06-15 5:03 PM (#36779 - in reply to #36777)
Subject: RE: XM Radio...
The factory unit mounts inside one of the cubby holes in the right side bag.
Completely out of the way of everything!
TimS
Posted 2009-06-15 5:06 PM (#36781 - in reply to #36777)
The XM Radio harness and plug plug is designed to fit into the front compartment of the right saddlebag.  A custom wiring harness would be required to get it into the trunk.
Also, the CB is mounted in the center of the trunk hole.  The CB would have to be moved to the side to make room for the XM unit.  The hardest part of this would be the custom harness and having a long enough antenna cable to reach the trunk.
HTH,
Tim
ebayjoe
Posted 2009-06-15 8:00 PM (#36801 - in reply to #36777)
Subject: Re: XM Radio...
East Ohio
My wife has the pioneer inno in her cage, I purchased an extra mounting kit for appx $50 and installed it in the left glove box opposit the fuel door, i also added the fm direct $20, it works great and only have the one subscription
Go Super Steel
