Check your brake lines...
mike s
Posted 2008-01-13 9:29 AM (#4143)
Subject: Check your brake lines...
Valdosta, GA
I was looking things over while taking a break yesterday and noticed they routed the rear brake line differently on the Vision than on the others. It now runs across the front, over the left side floorboard mount and back. At the front edge of the mount, I noticed my brake line was touching the mount and it had been rubbing a bit. A small adjustment and all is right again, but if left unchecked, I could see this becoming a big issue.
cjnoho
Posted 2008-01-13 10:29 PM (#4174 - in reply to #4143)
Subject: Re: Check your brake lines...
So Cal
I notice friday mine was rubbing too. Only took a sec. to tweak it some. But your right, could be a disaster if let go too long.
BUCKEYE
Posted 2008-01-14 8:03 PM (#4213 - in reply to #4143)
29 Palms California
thanx for the heads up.
