Heated seat install question
shane6727
Posted 2009-11-21 6:10 AM (#48181)
Subject: Heated seat install question
I got a heated seat for my vision street is this a plug and play install or do I need to cut wire?
Thanks,
Shane
1atom12
Posted 2009-11-21 7:52 AM (#48189 - in reply to #48181)
Subject: Re: Heated seat install question
Atlanta Area
When you pull your non-heated seat off you should see a small plug to the rear of your ECM. That is the heated seat plug. Should be plug and play!
Teach
Posted 2009-11-21 11:41 AM (#48195 - in reply to #48181)
Does your bike have the switches for the heated seat located on the left side under the edge of the seat behind the grab handle? I know the Ness Visions don't. If not you'll need the harness w/swt's but those should be a plug and play item as well.
Teach
Posted 2009-11-21 11:41 AM (#48196 - in reply to #48181)
1atom12
Posted 2009-11-21 4:12 PM (#48207 - in reply to #48181)
Atlanta Area
Switches are on the seat, not the bike... The harness should be laying where I said it would be. All the Visions share the same wiring harness heading to the back of the bike...
Teach
Posted 2009-11-21 5:30 PM (#48210 - in reply to #48181)
Are we talking factory seat or something else? If it is a factor seat the switches are on the bike, not the seat hence my question.
farlz
Posted 2009-11-21 5:50 PM (#48213 - in reply to #48210)
Okotoks, Alberta
My factory heated seat has the switches on the seat.
1atom12
Posted 2009-11-21 6:04 PM (#48214 - in reply to #48181)
Atlanta Area
I'm not trying to argue or start a fight, but, the factory heated seat switches are on the seat for sure...
Posted 2009-11-21 6:35 PM (#48215 - in reply to #48181)
I want to start a fight - the switches are on the seat and if anyone says otherwise, well, they're going to get...
devilboy
Posted 2009-11-22 9:37 PM (#48278 - in reply to #48181)
Central Florida
actually they are toggle switches
mine has red lit rocker switches that you can actually see and feel.
1atom12
Posted 2009-11-23 7:59 AM (#48283 - in reply to #48181)
Atlanta Area
Devil stirring the pot! Marc has the Corbin seat... Very nice BTW...
amessen
Posted 2009-11-23 8:13 AM (#48285 - in reply to #48181)
Belding Michigan
I too have the Cobin the seat is great but the heat is something else. I thought mine was broken but found that the switches are backwards the front switch heats the rear seat and the back switch heats the front seat. Pain in the A** now I have to take it off and rewire the switches. It does not appear that they made it easy to do. I should have found this earlier but I was in Florida last year when I got the seat for Christmas thanks to my wife. I did not think to check when it was 70 and 80 degrees this fall it came to light when the temps dropped to the 40's here in MI. Live and learn. Arch
GeekVisionRider
Posted 2009-11-23 9:47 AM (#48290 - in reply to #48214)
Fredonia, WI United States
1atom12 - 2009-11-21 6:04 PM
+1. The switches are on the seat. I installed mine in about 4 minutes. Easiest mod ever!
shane6727
Posted 2009-11-23 8:51 PM (#48330 - in reply to #48181)
Subject: RE: Heated seat install question
Thanks all!
