Clutch hand lever
glighto11
Posted 2010-03-08 2:11 PM (#54635)
Subject: Clutch hand lever
Central New York
I have short fingers and when I do a normal, relaxed grasp for the clutch lever I'm usually only catch it with the very tips of my fingers. I'm thinking that if I could just rotate the whole control group up, towards me, just a tad I would be able to get a more secure grab and not be afraid of slipping off someday.
My question is: If I loosen the mount clamps on the control assembly will it rotate or is it "keyed" in some fashion?
I know I can't go much because I need to keep the master cylinder somewhat level, but just a degree or two of rotation would make a big difference.
Len Rhymes
Posted 2010-03-08 2:56 PM (#54643 - in reply to #54635)
Subject: RE: Clutch hand lever
Jacksonville Florida
Might try placing a screw driver handle between the lever and the handle bar and bending the lever.
Posted 2010-03-08 10:09 PM (#54687 - in reply to #54635)
The control group is keyed to the handlebar by means of a pin that goes into a hole in the handlebar. I would think that you could either file the pin off, or elongate the hole if you wished, which would allow you to rotate the assembly a bit.
Blackjack
Posted 2010-03-09 10:46 AM (#54713 - in reply to #54643)
Cottage Grove, Mn
Len Rhymes - 2010-03-08 1:56 PM
I have heard that the lever can and has broken while uning this prosess so the next time i applied slow steady pressure and that worked. If you need to bend the lever a lot this might not be the anwser.
cw1115
Posted 2010-03-10 2:30 PM (#54786 - in reply to #54635)
Subject: Re: Clutch hand lever
Ruskin, Fl
I used the screwdriver and hand pressure to bend mine when I first got the bike. You have to be careful not the apply pressure at the end of the lever past the notch. Came out perfect. I was able to apply clutch with two fingers. Only thing was tha ball at the end made contact with the end of the handle bar. Not a problem at all. I don't normally pull the lever that far unless I'm sitting at a light. Than I did something REAL stupid. I had the lever covered with a rag to prevent marring it. I forgot about the relief cut, put the screwdriver handle at the end and pulled in the middle. My intention was to flair the end a little more. Broke the end right off. When I replaced it, I performed step one again and left well enough alone.
Edited by cw1115 2010-03-10 2:31 PM
