Vision and the red Sears jack
Biscuit
Posted 2010-04-12 11:06 AM (#57299)
Subject: Vision and the red Sears jack
Midlothian, Va.
I can't find the sweet spot to get my Vision lifted with this jack. Will it work with this jack and if so what is the secret?
chesshiretuna
Posted 2010-04-12 11:24 AM (#57300 - in reply to #57299)
Subject: Re: Vision and the red Sears jack
I have the yellow one. I had to make 4 pads(about 1.5 tall) to mount in the holes on the top and position the jack so the rear arm is in line with the exhaust crossover. and the jack is stopped by the kick stand. This works for me and i can spin the bike around on it. The bottom of the engine is not flat. It took me some practice to find the sweet spot
Posted 2010-04-12 11:32 AM (#57302 - in reply to #57299)
chesshiretuna,
Can you post a picture of those pads?
Bubba
Posted 2010-04-12 12:03 PM (#57305 - in reply to #57299)
I do nothing. Just jack it up with my red one.
Posted 2010-04-12 12:22 PM (#57307 - in reply to #57299)
I thought this was going to be a childrens story. But none the less I've the red Sears jack and it is a rock-a-billy because of the curvature of the engine belly. However, there seems to be some nubs that happen to line up exactly with the padded jack surface and that is where I place mine with about an inch poking out on the left side. Kick down will not really let it go much further than that. I would like to have some curved padding mounted to the jack to fit the engine especially when it is on the upper limits and locked. Not the best system but it does work.
Biscuit
Posted 2010-04-12 12:37 PM (#57309 - in reply to #57299)
Midlothian, Va.
Pictures would be good for this old boy also, thanks.
Posted 2010-04-12 1:24 PM (#57317 - in reply to #57299)
in what proximity to live to Richmond-Petersburg Biscuit? North - East - South - West???? I'm just east of Petersburg, close to New Bohemia...
Biscuit
Posted 2010-04-12 1:53 PM (#57318 - in reply to #57299)
Midlothian, Va.
Not far, I'm in Midlothian. Would like to meet you and have a look see.
Bubba
Posted 2010-04-12 2:13 PM (#57320 - in reply to #57299)
Heres a link of the pictures of lifting my Vision with the red Sears jack. I use no pads and have lifted al 4 of my Vics with no issues.
http://thevog.net/forums/display_topic/id_4272/
Posted 2010-04-12 2:15 PM (#57321 - in reply to #57299)
I work dead next to the powhite & mid. Trpk.
Biscuit
Posted 2010-04-12 3:01 PM (#57324 - in reply to #57321)
Midlothian, Va.
varyder - 2010-04-12 3:15 PM I work dead next to the powhite & mid. Trpk.How about lunch sometime? Retired so I have plenty of free time.
Biscuit
Posted 2010-04-12 3:08 PM (#57325 - in reply to #57320)
Midlothian, Va.
Pictures do help a lot, thanks. I had 3 VTX's before the Vision and a guy in Texas fabed a metal stand for the VTX also worked on HD's and maybe others and once the bike was jacked up slide the stand under and drop the bike down it wasn't going anywhere. Didn't need straps and was able to climb up on the bike to run it through the gears if needed and it was rock steady. Won't work on the Vision because the rails were outside the lift bars. I am really going to miss it.
lennyb
Posted 2010-04-12 4:13 PM (#57331 - in reply to #57300)
Perry Hall, MD
Here is a template for a jack block from an earlier posting I believe it was from a friend on the other side of the pond.
(Jack Template.jpg)
Attachments Jack Template.jpg (66KB - 15 downloads)
Posted 2010-04-12 4:40 PM (#57333 - in reply to #57299)
i had mine on the RED sears jack just last week when i cleaned the rear wheel. Once you find the spot its no longer an issue.. i used the red jack to remove my rear wheel and take it to the dealer for a new tire install. works great. ive had this jack for 7 years now
chesshiretuna
Posted 2010-04-12 4:56 PM (#57334 - in reply to #57299)
Subject: RE: Vision and the red Sears jack
Here are pictures of my plugs. I made them from some plastic rod that was leftover from a job.I think wood blocks will work too. The placement of the jack takes some practice, but when you find it and jack the bike up both wheels clear the ground. I do this to turn the bike around in my shop so I can ride out. Just remember to strap it down untill your comfortable with it. You can drop your bike off these jacks. Also release the jacks safety bar before lowering it.
Edited by chesshiretuna 2010-04-12 5:03 PM
(IMAG0009 (Medium).JPG)
(IMAG0011 (Medium).JPG)
Attachments IMAG0009 (Medium).JPG (59KB - 12 downloads)
Attachments IMAG0011 (Medium).JPG (47KB - 7 downloads)
Posted 2010-04-12 8:21 PM (#57348 - in reply to #57324)
Biscuit - 2010-04-12 4:01 PM
This week may not work, but we can plan for next week if you'd like. What's your favorite place around here. I can't seem to find one except the American Grill or something like that.
ingle51
Posted 2010-05-06 3:56 PM (#59234 - in reply to #57299)
NE Florida Jacksonville
I use a Crew Line motorcycle jack and have found that using the regular square rubber furniture cups on each of the four corners give me enough clearance to jack the Vision without problems. You can stack the cups as high as necessary and they are cheap at Home Depot or Lowes. They also make them round but they are harder to find.
