How to clean melted gunk off exhaust?
audioguy
Posted 2010-04-16 11:37 AM (#57661)
Subject: How to clean melted gunk off exhaust?
Spokane, WA
I seem to have a habit of touching the right exhaust heat shield with the sole of my boot. I don't know when or how it happens, (maybe dismounting?) but it leaves melted shoe goo on the heat shield.
The first time it happened, I tried a light solvent (like goo-gone) to soften the stuff, then chrome polish for the rest and the stain. The problem is, of course that chrome polish is quite abrasive and I'm worried about polishing right through it into the underlying nickel plating.
Any ideas? I thought perhaps a stronger solvent in the first step, but I don't know what that would be.
Thanks,
--jim
donetracey
Posted 2010-04-16 12:08 PM (#57664 - in reply to #57661)
Subject: Re: How to clean melted gunk off exhaust?
Pitt Meadows, BC Canada
Have a read of this old thread - maybe give you some ideas:
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=5522&pos...
audioguy
Posted 2010-04-16 12:55 PM (#57667 - in reply to #57664)
Spokane, WA
Thanks, Don.
I did search around a bit before posting, but obviously didn't hold my head right. The Easy-Off oven cleaner perhaps sprayed onto a shop towel instead of direct (to avoid overspray) and a hot exhaust just might do it.
Thanks!
--jim
donetracey - 2010-04-16 10:08 AM
kenhiggins
Posted 2010-04-18 12:01 PM (#57838 - in reply to #57661)
Montreal, QC Canada
I use some stuff called FLIX. Comes in a tube, just rub on warm pipes and rub. Removes heel scuffs and other gunk on the pipes.
#57
Posted 2010-04-18 12:15 PM (#57841 - in reply to #57661)
I use the Spray & Wipe Instant Detailer from Pure Victory Gear along with some #0000 steel wool.
It's the stuff Larry the Polish guy sells at all the Victory Events and you can buy at your local dealer.
audioguy
Posted 2010-04-18 12:28 PM (#57842 - in reply to #57661)
Spokane, WA
Thanks to all for the great suggestions.
I ended up using Goof-Off and spray carb cleaner this time around, but it took a LONG time and many applications for the solvents to soak through the gunk to the point where I could wipe it off. Since I'm a car/bike/equipment/fixtures/whatever polishaholic, I'm going to pick up a tube of Flitz to try for this and other projects.
--jim
OldGringo
Posted 2010-04-18 2:08 PM (#57853 - in reply to #57661)
Republic of Tejas
Ken, is that FLIX or Flitz? I use the latter which is also great for an occasional buffing of your old 1911 style 45. Great way to cure FTF's.
Posted 2010-04-18 4:11 PM (#57859 - in reply to #57841)
#57 - 2010-04-18 1:15 PM
I got scratches in my pipes now, you can see them on an angle. I'll use a wet terry or the hot pipes and that seems to work good. Then I'll go over them with the Pure Victory when they are cold, minus the #0000 steel wool to get them to shine.
Edited by varyder 2010-04-18 4:12 PM
kenhiggins
Posted 2010-04-18 5:20 PM (#57867 - in reply to #57661)
Montreal, QC Canada
Hey OldGringo,
You're right. It is FLITZ. I keep it in the bike so I was going from my bad memory. The stuff works great.
