new XM no FM or sound?
IndyVision
Posted 2010-05-08 9:22 PM (#59421)
Subject: new XM no FM or sound?
I had the XM radio installed. There is no sound coming out of the speakers for XM. FM will play if the bike is started on FM, but if you toggle through AM, WB, Ipod, FM will not come back on. The IPod plays fine. XM shows channel, and song getting played. Any suggestions on whats wrong? I did notice the screen is offset to the right when XM is on. Only half the song's title can be read.
Posted 2010-05-08 11:03 PM (#59427 - in reply to #59421)
Subject: Re: new XM no FM or sound?
IndyVision,
I do not know the answer off hand but some more information might help.
Has it ever worked or is it a new install?
What year model is the Vision? Do you have the CB? What versions are the SW (software) and HW (hardware) of the audio components that you have installed?
You can find out the HW and SW data by....
....from a BigVic post
You can find this info out by going into the Radio System Diagnostic menu on your radio. to do this follow the instructions below.
1. Turn the ignition switch to ACC and turn the radio off (Victory Motorcycles is shown on display)
2. Turn ignition switch OFF.
3. Turn ignition switch back to ACC.
4. PRESS & HOLD the #1 preset button and MODE button while turning the radio power ON.
5. The diagnostics mode is entered. Press MODE to toggle through the diagnostic functions. To exit diagnostics press Power button.
NOTE: A "Watchdog Error Cleared" message will occasionally appear as the first thing displayed. This can be ignored, it is an internal software notification.
6. The first screen shows the radio software (SW) & hardware (HW) revision.
7. The second screen is used to check buttons and button wiring circuts related to the radio / com. system. The display contains two lines of "Zeros". Each location corresponds to a radio button on the radio, handlebar switches, or passenger switches. A (0) represents a button not being pressed. A one (1) represents a button being pressed. If a "1" appears at an address in the upper or lower row of the radio display the button and circuit wiring are functioning correctly.
8. The third screen shows Tuner location, which will always be set to USA.
9. The forth screen list the status of the radio amplifier.
10. The fifth screen displays vehicle speed. This can be used to test if the radio is receiving the vehicle speed CAN message from the PCM. It could also be used to test for a faulty CAN bus connection to the radio. If the speedometer is working but the radio is showing zero speed, it has no CAN connection.
11. If there are no accessories installed on the vehicle, the display will go back to the first screen. If accessories are installed, there are additional diagnostics screens for each accessory, showing the SW & HW revisions, etc.
Ride Safe
IndyVision
Posted 2010-05-08 11:19 PM (#59430 - in reply to #59421)
The XM was just installed. I picked the bike up today. I noticed the FM would not play as I was going home. If I put the radio on FM, turn the bike off and wait a few minutes, turn the radio back on, the FM will play sometimes. If I start on FM and it plays and I toggle back to FM, it will not play. It just did it a couple minutes ago. I'll check the software tomorrow.
