vision mufflers
Posted 2010-08-26 9:12 PM (#68007)
Subject: vision mufflers
How do you get them off?????
I un did the two mounts under the saddle bag and the muffler clamp and can't budge them.
Help
Posted 2010-08-26 9:14 PM (#68008 - in reply to #68007)
Subject: Re: vision mufflers
work, work, work. I soaked mine with some of that liquid wrench stuff and let them set several hours. They slid right off with a little twisting.
Posted 2010-08-26 9:29 PM (#68010 - in reply to #68007)
I didn't say there is that mount under the bag that is a stud how do you get past that
Posted 2010-08-26 9:43 PM (#68013 - in reply to #68007)
I'd have to think, it has been a while, but if I recall, twist the muffler and it comes away from the stud...
Posted 2010-08-26 9:47 PM (#68016 - in reply to #68007)
I will try it in the morning
Thanks
Lotzafun
Posted 2010-08-26 10:14 PM (#68019 - in reply to #68007)
Rockford, IL
One of my mufflers came off with a couple of twists. But I had to use a "band" type oil wrench and a small amount of hammering and grunt force to get the other one off.
wroman
Posted 2010-08-27 8:06 AM (#68025 - in reply to #68007)
Gettysburg, 2008 Tour Premium
Wait!!! There are three bolts that attach the mufflers to the subframe. The two above the mufflers and one at the tail end. the muffler and crossover clamps shoud be loose. Removing the sliver bodywork panel is will allow wiggle room.
Posted 2010-08-27 9:01 AM (#68032 - in reply to #68007)
thread moved to Vision Tech Q&A
