gear indicator woes , where to now?
martyq
Posted 2011-03-29 7:51 PM (#82717)
Subject: gear indicator woes , where to now?
Hi all , my 09 Vision has the gear indicator display problem . In detail , It displays 1-2 when in first repetedly then 2-3 when in second and then works fine from 3rd up . I have had a new sensor put in as well as the bolt fix , after which it got worse . I indicates 2nd now as soon as I go into first , as I let out the clutch it jumps back and forward to 1-2 and the same in 2nd but 2-3 . I have not noticed it any better after an oil change , and I only use Victory oil . They are talking about fitting a new dash now !Is anyone having this problem on the X Country , as I believe they are much the same set up as the vision , and ideas about a permanent fix ???? Cheers MartyQ
RodMyers
Posted 2011-03-30 6:34 AM (#82740 - in reply to #82717)
Subject: RE: gear indicator woes , where to now?
I just learned to live with it on my '08.
I had the same stuff replaced, as you. Still happens.
jeffmack
Posted 2011-03-30 6:58 AM (#82741 - in reply to #82717)
Subject: Re: gear indicator woes , where to now?
hate to be the nay say'er, but i never look at the indicator. kinda just know what the bike doing now. I wish it was right, but not worth hauling it in for them to try and fix.
