Trunk removal?
Bullyrider
Posted 2011-06-24 9:26 AM (#89527)
Subject: Trunk removal?
Newnan Ga
Quick question? Can someone tell me how to unplug the trunk on the CC? I see where the wiring goes up into the left side of it but don't see any kind of panels that come off to get to it. Or, am I looking in the wrong place?
Thanks in advance,
Chuck
Victory XC
Posted 2011-06-24 10:16 PM (#89604 - in reply to #89527)
Subject: Re: Trunk removal?
The plug is under the left side panel of the bike.
Follow the wiring out of the trunk & along the support brackets; it'll be pretty obvious.
Bullyrider
Posted 2011-06-25 7:41 AM (#89614 - in reply to #89604)
Newnan Ga
Thank you.
ltbiker
Posted 2011-06-30 3:31 AM (#89919 - in reply to #89614)
Chandler, AZ
Not the easiest thing to do removing the trunk. Make sure after you unplug the wiring pigtail that you "thread" it through the saddlebag area before you pop it loose at the back, or the wiring pigtail will hang up on something and you'll be standing there with the HEAVY trunk and can't move any further because the wiring is caught.
