Heated Seats
XSuzukirider
Posted 2011-08-02 9:30 PM (#92432)
Subject: Heated Seats
Joplin, Mo
When I bought my Vision, I had understood they came stock with heated seats. I found that mine does not have them, are the supposed to be stock on the 2011?
Dave
Posted 2011-08-02 10:05 PM (#92434 - in reply to #92432)
Subject: Re: Heated Seats
Not sure if they are stock or not....Do you have a heated grips switch on the dash? If so, check near the grab handle on the left side under the edge of the seat for the TWO toggle switches that control the heated seats. If you have them.......they are three position switches with the center being OFF.
Ride Safe
Edited by radioteacher 2011-08-02 10:06 PM
opas ride
Posted 2011-08-02 10:31 PM (#92436 - in reply to #92432)
Sure you do not have heated seats? Stock on all 2011 Visions except 8-ball...As stated above, the switches that control the seats are on the left side of the seat near the rear edge of drivers seat......
StanLaurel
Posted 2011-08-05 12:47 PM (#92699 - in reply to #92432)
Robins AFB, GA
Stock on my 2011 - dreaming about the day I'll first use it. It has cooled down to 105 today in Little Rock.
BlueByu
Posted 2011-08-05 12:57 PM (#92700 - in reply to #92432)
Houston, Tx
Was it purchased used and previous owner put a different seat on it? I've found none of the other Vic seats (Ness, 8-ball) have heating elements in them. If the seat is stock, then it should have them as far as I'm aware. They can be a bit tricky to locate ... run your hand on the left underside of the seat, just under the passenger section. First one you'll find is the driver toggle and the rear is the passenger. As mentioned, three positions... high/off/low.
bigfoot
Posted 2011-08-05 4:59 PM (#92715 - in reply to #92432)
Akron Ohio area
First thing you should do is read your owners manual.
That will answer 99.9% of your questions.
bigfoot
Posted 2011-08-05 4:59 PM (#92716 - in reply to #92432)
Akron Ohio area
<p>Damn double post, Sorry</p><p> </p>
Edited by bigfoot 2011-08-05 5:00 PM
XSuzukirider
Posted 2011-08-09 7:26 AM (#92980 - in reply to #92700)
Joplin, Mo
Thanks for the help, I found them. There was a picture of the switches in the manual that showed switches like for the hand grips, and these are up under the seat and not the same type switch.
