For those of you with Ipod charging issues here is the answer
Mattchristiani
Posted 2011-08-12 2:51 PM (#93314)
Subject: For those of you with Ipod charging issues here is the answer
Cedar, Michigan
CableJive dockStubz Charge Converter and 30-pin Pass Through Adapter. I got mine on eBay for $25 delivered. Works like a charm.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200606673455&vie...
cook06vegas
Posted 2011-08-16 11:42 AM (#93708 - in reply to #93314)
Subject: Re: For those of you with Ipod charging issues here is the answer
Lansing, MI
That's a cool idea!
herk
Posted 2011-08-16 12:37 PM (#93717 - in reply to #93314)
will this work with the old i pod cable that dont charge like mine on the o8 vision and do i have to plug it in to get it too work properly or will it just charge of the i pod cord off the bike.
Posted 2011-08-16 1:09 PM (#93726 - in reply to #93717)
herk - 2011-08-16 12:37 PM
Yes.
nailer
Posted 2011-08-16 1:59 PM (#93733 - in reply to #93726)
Albuquerque, NM
So this device will attach to the $50 victory ipod cable and provide the same charging functionality and the vic $100 cable?
Posted 2011-08-16 7:00 PM (#93766 - in reply to #93733)
nailer - 2011-08-16 1:59 PM
For a 2008 and 2009 Vision the answer is yes. But it does make the cable a little longer. I can still charge the iPhone 4 and use it as an iPod with an Otter Box over the phone but it fills the glove box.
I whole heartedly recommend getting an old iPod Nano 3 from a Pawn Shop....cheap and leaving it in the Vision. But if you have to have a new iPod Nano the charging adapter works fine.
Have you read the iPod guide for the Vision?
Edited by radioteacher 2011-08-16 7:01 PM
Mattchristiani
Posted 2011-08-16 8:04 PM (#93770 - in reply to #93717)
Cedar, Michigan
herk - 2011-08-16 1:37 PM
Yes, I have an 08 with the white Ipod cord and it functions perfectly and charges it. This little piece is pure magic.
Johnnyg
Posted 2011-08-24 11:45 PM (#94589 - in reply to #93314)
Subject: RE: For those of you with Ipod charging issues here is the answer
West Chester, PA / 08 VVPT
Do they make a $100 cable for the 08/09 Vision? The only one I can find (iPod KIT part # 2878628 ) has 2 plugs on it but my 08 only has one.
(ScreenCapture_1050.jpg)
(ScreenCapture_1051.jpg)
Attachments ScreenCapture_1050.jpg (6KB - 0 downloads)
Attachments ScreenCapture_1051.jpg (7KB - 1 downloads)
Posted 2011-08-25 8:17 AM (#94601 - in reply to #93314)
Johnnyg,
Welcome to the forum.
Read the document at the link below. It lays out what works with what year model Vision.
http://www.vision-riders.com/bb/forums/get-attachment.asp?attachmen...
Edited by radioteacher 2011-08-25 8:21 AM
Johnnyg
Posted 2011-08-25 10:44 AM (#94622 - in reply to #94601)
Thanks radioteacher
From your document:
Fix2: The easier way to fix the same issue for the 2008 and 2009 Visions is the newer Black cable (part number 2877894) that will charge any iPod/iPhone for $99.99. It has a box in the cable that coverts the voltage and sends it to the correct pin to charge the iPod/iPhone.
I found part # 2877894 the other day, but when I looked at it on the victory site, it does not seem to be the right part (see the picture below) Are they just listing the wrong picture?
Edited by Johnnyg 2011-08-25 10:46 AM
(ScreenCapture_1053.jpg)
Attachments ScreenCapture_1053.jpg (29KB - 0 downloads)
cw1115
Posted 2011-08-25 5:58 PM (#94693 - in reply to #93314)
Ruskin, Fl
I bought that little inline stub thing. It works but I have two issues with it. Using it with an iphone it barely fits in the glove box. I have to put a severe bend in the cable to get it in. Number 2, it just pushes into the bottom of the device so he can disconnect on you.
Posted 2011-08-27 8:04 AM (#94862 - in reply to #94622)
Johnnyg - 2011-08-25 10:44 AM
Thanks radioteacher
From your document:
It is either the wrong picture or the cable is built to fit different bikes depending on what connector is plugged it. For over three years I have been using the same old White connector in mine.
I use Gen 3 iPod Nano's I buy at pawn shops. So charging is not an issue. I have two and swap them out when the mood strikes me or to add/change my lists.
I also have an iPhone 4 that I use the Charging Adapter with.....Like CW said it is a really Tight fit in the glove box.
Ride Safe...and Rock on!
